GT lowering the hp boost from 7000rpm to 6k
manicdan
Post by manicdan »
i have an 05 vibe GT 6spd:when i hit the gas i feel it really kick in exactly at 7k rpms, ive herd from others its at 6k for them and i was wondering whats the easiest way to get that lowered. ive herd of systems like camcon and unichip, but ive never used one and i dont wanna put the money out until im sure i know what im working with
northvibe
Post by northvibe »
I think just getting a 2003 ECU from a GT will do that. I think they brought up the rpm for lift in 05 or 04....all i know is that the 03 ecu is a most wanted part for the newer ones to get more "lift" from it.
DopeVibeGT
Post by DopeVibeGT »
I'm always wondering how the GT's lost 16 HP from 03 to 06? More smog/fuel stuff? I think if I was to get a new Vibe now, I'd get a base and put the SC on it.
manicdan
Post by manicdan »
will putting in an 03 chip mess things up at the DMV?
AKLGT
Re: (DopeVibeGT)
Post by AKLGT »
Quote, originally posted by DopeVibeGT »I'm always wondering how the GT's lost 16 HP from 03 to 06? More smog/fuel stuff? I think if I was to get a new Vibe now, I'd get a base and put the SC on it. yes the newer gt's are a lot less powered. with it only being 164 hp, why not get the base and turbo it? the 1zz can handle a lot more power than the 2zz.
AKLGT1998 Subaru 2.5RS
DopeVibeGT
Re: (AKLGT)
But you can turbo the 2ZZ and get 75-100 more HP...(Just found this out after my last post)
AKLGT
Post by AKLGT »
yes, there are now turbo kits for the 2zz. however, i'm still skeptical on how long the engine will last without upgrading a lot of internals.
DopeVibeGT
Re: (AKLGT)
Unless you disable the valve change over or whatever it does?
goodvibe
Post by goodvibe »
If your not going to use lift, why would you bother with blowing a GT instead of the cheaper lower compression base. It's easier to turbo and power is limited by the tranny to aroung 250HP anyway.
DopeVibeGT
Re: (goodvibe)
Thats why ya get a nice, new ACT clutch along with the turbo kit.
engineertwin2
Post by engineertwin2 »
I know some of the reduced power in the 04+ GTs is associated with higher lift engagement points, but I thought the primary driver behind the Vibe losing HP was the more stringent regulations on how HP is determined (SAE shored up their rules and now only one method is determined)...I guess I'm wrong here...
drunkenmaxx
Re: (engineertwin2)
Post by drunkenmaxx »
nah, you're right man. the new AWDs are rated at like 118!!
DopeVibeGT
Re: (engineertwin2)
With less HP than the '03, are the 04+ GT's slower? That would bite.
engineertwin2
DopeVibe...what I'm suggesting is that they didn't do anything to change the power output (other than a slight lift engagement adjustment). Rather, they simply standardized the method used for reporting power and as a result, some of the numbers are now lower.As for speed, I'd say that both the '03 GT and the '04 GT have the same profile so they are both drag limited to the same number...which one will get their quicker - maybe the '03, but the '04 may have less wear or a better driver. Bottom line, I believe asking if the '03 is faster than the '04 is like asking if the '06 Viper is faster than the '05 Viper - it's really the same car and 98 out of 100 won't notice if you are missing a couple of ponies...
DopeVibeGT
Re: (engineertwin2)
Ok, just wondering. Just seems 16HP loss would be noticeable, but I do see what you're saying. Now, for keeping it in lift, can you do it with a 7K lift?I know with the '03 lift, it just stays in lift when changing gears.
engineertwin2
I've never been able to maintain lift...the engine begs to drop in revs and I've never been able to keep it engaged...I don't know if having the short shifter makes a difference though...
drunkenmaxx
Re: (engineertwin2)
if i'm not mistaken, the 04 came up a bit shorter than the 03 due to some kind of friggin' emissions thingamajigger.
millster
Re: (drunkenmaxx)
Post by millster »
DM is correct. The '04 differs from the '03 because of the emissions air pump. The '04-'05 difference is due to ratings standardization.Post edited:Thanks for the correction "DM"!
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
drunkenmaxx
Re: (millster)
i am DM now dammit!
savedbyzero
Post by savedbyzero »
It is possible to stay in lift in the '03's. JustinVGT can attest for that as I took him for a ride in mine about a year and a half ago! AS for the drop in power, I would feel that it would be totally noticable. Any little bit in this weight of a car can be felt. The lift engage point set at 7k, I feel would be impossible to keep there from shift to shift. It's too bad Pontiac has let down our community performace wise. They jumped out of the gate well, but seem to be draggin their feet as of recently. I think the general market they were shooting for, didn't quite respond as they had hoped, excluding the peeps on this board!As for the durability and boosting potential of the 2ZZ, well, you're gonna have to do internal work to be able to push more air through. The weakest like by far on these motors is the oil gear. I don't recall anyone stepping up and building us a improved piece, as of January '06 at least. I searched high and low for an aftermarket piece during my rebuild. none to be found. MWR has everything else you need though, pistons, crank, rods, bearings, etc.
THIS IS WHAT I DO...http://www.studiothisis.com
goodvibe
Re: (AKLGT)
Post by goodvibe »
Quote, originally posted by AKLGT »yes the newer gt's are a lot less powered. with it only being 164 hp, why not get the base and turbo it? the 1zz can handle a lot more power than the 2zz.It's easier to boost a 1zz because it has lower compression but the 2zz is still a stronger motor and doesn't need bearing upgrades for big power. Rods, bearings etc are stronger and there's extra oil squirters for under the pistons. Cylinder walls are harder. Trannies on both is what limits power to below 275 hp.
