week old and already had to have it in the shop!!!!!
keithvibe
Post by keithvibe »
Yes, you read correctly. I purchaced an 06 awd vibe on the 18th of this month and today it had to back to the dealer for a starting issue.Turns out the battery had a dead cell in it. It was replaced at no charge with a brand new AC Delco . Wish it was a "yellow top" Hope it dosen't happen again
BlueCrush
Re: week old and already had to have it in the shop!!!!! (keithvibe)
Post by BlueCrush »
Vibes have been known to have crappy batteries. Glad you got it replaced with out any problems.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
My experiences have been that, on the large scale, ACDelco batteries are actually pretty reliable and trouble-free. I suspect (but have no evidence to support my argument that) the batteries being installed in the Vibe from the factory are outsourced from Toyota and are then getting a Delco label slapped on them. But the replacements being installed by dealers are the real deal ACD, so I am pretty confident you shouldn't have any issues with that new battery.I had unintentionally killed my battery on my G6 by listening to the radio with the engine off for about 6 hours straight...because I did not recharge the battery properly (using a trickle charger), the battery never held a charge and I jumped the car more times in a month then I could have ever imagined. But when the dealer put in a new ACD battery about 2 months ago, the problems went away. Not even a slight starting hesitation from my car since then.
ToolGuy
Post by ToolGuy »
Batteries have a HUGE warranty dollar tied to them. Often they are not properly charged from the plant and get "lot rot" as it is called. If yours had a bad cell then that was a manf issue. We sell a battery service center to prevent lot rot and re-condition batteries on new and used cars to cut down on their replacement. I have never had a bad experience with a Delco and my 2003 Vibe still has its original.Do not feel bad though! My New 2007 Compass needed a new clock spring when the radio steering wheel controls and horn acted up and then stopped working altogether! A defective part right as I left the lot.
NewNeptune
Re: week old and already had to have it in the shop!!!!! (MiVibe-ToolGuy)
Post by NewNeptune »
Quote, originally posted by MiVibe-ToolGuy »I have never had a bad experience with a Delco and my 2003 Vibe still has its original.I did! The AC Delco battery in my Malibu suddenly failed after about 1 year and half. I went out to leave one day and it keyless entry wouldn't work and the car wouldn't even crank. Worked fine the night before and was dead the next day.
2006 Pontiac Vibe Base, Automatic, Power PackageSony CDX-GT300Upgraded Horns
Atomb
Post by Atomb »
not to get you worried...but some bells are ringing.when you say 'starting issues'...do you mean it takes more turnovers by the starter before the engine starts?does this happen when the car has only been off for a few minutes?i just know that i've had dealers 'solve' my problem before by taking the simplest solution...instead of really digging into the problem.as you'll see here: http://forums.genvibe.com/zerothread?id=20641there is a 'starting problem' with many 06 vibes.i really hope a new battery solves your problem!
2002sportside
Re: (Atomb)
Post by 2002sportside »
Quote, originally posted by Atomb »not to get you worried...but some bells are ringing.when you say 'starting issues'...do you mean it takes more turnovers by the starter before the engine starts?does this happen when the car has only been off for a few minutes?i just know that i've had dealers 'solve' my problem before by taking the simplest solution...instead of really digging into the problem.as you'll see here: http://forums.genvibe.com/zerothread?id=20641there is a 'starting problem' with many 06 vibes.i really hope a new battery solves your problem!That thread is too long to read to see if this is in there... but, there is a TSB out for the fuel pump in '05 Vibes causing hard starts.Quote »Fuel System - Engine Cranks/No StartBulletin No.: 05-06-04-064Date: October 17, 2005TECHNICALSubject:Engine Cranks/No Start (Replace Fuel Pump and Filter (Module) Assembly)Models:2005 Pontiac Vibewith Front Wheel Drive (FWD) and 1.8L Engine (VIN 8 - RPO LV6)ConditionSome customers may comment that the vehicle cranks but will not start.CauseThe cause of this condition may be due to insufficient fuel pressure after the vehicle has been parked for an extended period of time.CorrectionFollow SI diagnostics for the no start condition. If results lead you to fuel pump and filter (module) assembly replacement, or no other concerns are found, then replace the fuel module assembly.I don't have a warm start problem, but I do have the cold start one. Since I'm slightly modded I think I'm just going to replace the part on my own and save myself the hassle of going to the dealer...
2005 Moonstone Base Vibe 38k as of October, 2010 (41k as of 7-15-11)Moon & Tunes, power package, automatic, center console power port added
