Changing my spark plugs
erabralop
Post by erabralop »
How the heck do you get that plastic deck off?The two bolts are a snap, but those factory clips I just can't figure out.
BlueCrush
Re: Changing my spark plugs (erabralop)
Post by BlueCrush »
You have to get a flathead screwdriver and pop them out. You will be able to put them back in when done. They will only last a few times popping then in and out before they are trashed. Then you can get new ones from Toyota or just leave them out like I did. Good Luck!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
erabralop
Post by erabralop »
Sweet deal, managed to only break one.
ToolGuy
Post by ToolGuy »
I lost one of those plastic fasteners, somewhere in the engine the second time I had it off... I have since replaced both with bolts because the holes are threaded!
JohnC
Re: Changing my spark plugs (MiVibe-ToolGuy)
Post by JohnC »
Quote, originally posted by MiVibe-ToolGuy »I have since replaced both with bolts because the holes are threaded! Good tip, thanks.Does the cover actually do anything, or is just for looks?
ToolGuy
Re: Changing my spark plugs (JohnC)
Post by ToolGuy »
Kind of mostly for looks but I suppose it keep debris from sitting on top of the engine. It does have a pad under it too possibly for noise...
binary
Post by binary »
Solid lifter noise reduction...tap tap tap tap tap tap tap tap tap ...
