You have to get a flathead screwdriver and pop them out. You will be able to put them back in when done. They will only last a few times popping then in and out before they are trashed. Then you can get new ones from Toyota or just leave them out like I did. Good Luck!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
I lost one of those plastic fasteners, somewhere in the engine the second time I had it off... I have since replaced both with bolts because the holes are threaded!
Quote, originally posted by MiVibe-ToolGuy »I have since replaced both with bolts because the holes are threaded! Good tip, thanks.Does the cover actually do anything, or is just for looks?
