Drove Vibe for first time, impression-handling/steering is fair-suggestions to improve?
lexicon
Post by lexicon »
Drove the Stock automatic for the first time. Impression is that the steering responsiveness is somewhat slow. I am used to a Supra, what do you suggest to do to give you that improved tossability and responsiveness to the steering wheel?The only improvements I have read about are sway bars and springs.Will these make the car more nimble in terms of being able to turn wheel and get the car to respond more quickly?
2005 VibeAutomaticStockNon AWD125 hp model
NascarXprt
Re: Drove Vibe for first time, impression-handling/steering is fair-suggetions to improve? (lexicon)
Post by NascarXprt »
also a strut tower brace will most probaly help it. but yes springs and swaybars will help with the steering response.
Sounds like what you really need is some steering gear with a quicker response - but I highly doubt a higher performance rack exists for this application. Mine drives crazy now, the rack is pretty screwed up - it's all over the place in the blink of an eye, I guess if you bought a Vibe we could trade rack and pinions. j/kYou can always go with a different tire, that could make all the difference in handling and steering response as many here have found.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
NSimkins
Global Moderator
Post by NSimkins »
Quote, originally posted by lexicon »The only improvements I have read about are sway bars and springs.Springs and sway bars will make the most improvement in steering response as well as high-performance tires.
northvibe
Post by northvibe »
i concur,good tires, strut tower bar, front and rear sway bars and new springs or coil overs, would help it out.
AKLGT
Post by AKLGT »
1. springs2. strut bar3. sway bars
AKLGT1998 Subaru 2.5RS
ballrub
Re: (trdvibe)
Post by ballrub »
4. Bigger wheels / lower profile performance tires!
2003 Vibe GT Shadow............"The SHADOW Knows!"Dec. 2004 Vibe of the Month html/vo...shtml
Re: Drove Vibe for first time, impression-handling/steering is fair-sugge ... (lexicon)
Quote, originally posted by lexicon »I am used to a Supra, what do you suggest to do to give you that improved tossability and responsiveness to the steering wheel?Coming from a supra, maybe some amount of lowered expectations are required. I came to the Vibe from a land yacht, so the nimbleness and responsiveness of the Vibe steering were much better than what I had before.
