05 Accessory Drive Belt R/R
Mach2
Post by Mach2 »
35,400 miles on the 05 Vibe and was wondering about the scheduled R/R mileage for the Alternator/Air Cond Accessory Belt. I was looking at it and didn't see the tensioner pulley where you could loosen and remove the belt by loosening the pulley. Is R/R'ing this belt a home done deal or is it a Dealer only job?
Re: 05 Accessory Drive Belt R/R (Mach2)
I did mine at 100K miles. Helps to have small hands, which I don't.there's some info at http://forums.genvibe.com/zerothread?id=16476
Mach2
Re: 05 Accessory Drive Belt R/R (joatmon)
Post by Mach2 »
Thanks joatmon, the pic's will work.
Lancer
Post by Lancer »
I've swapped mine about 4 times trying to get the right configuration with the aftermarket pulleys and s/c.The best way to do it is to remove the right frnt tire and splash shield in the wheel well. You'll be able to reach all the pulleys then.
Mach2
Re: 05 Accessory Drive Belt R/R (Lancer)
Post by Mach2 »
Thanks too for the tips Lancer. I have a stock Vibe, not a GT and am thinking about preventative maintenance.
Vibe_dude
Post by Vibe_dude »
did mine 3 weeks ago,had 98,000kms, on stock belt......went in under the hood........2 ppl helps alot.........took about 10 mins.
Mach2
Re: (Vibe_dude)
Post by Mach2 »
I'll stay with the stock belt to 50,000 miles, then change it. I'll get one now and keep it in the car until then, just in case.
Mojo72
Re: (Mach2)
Post by Mojo72 »
I just changed the accessory belt at 82K+ miles w/ a Dayco Rib (Part #5060725) belt. I didn't take off the RF tire, but was able to put an old wire hangar to good use in pulling up the belt to loop it around the tensioner pulley. That said, I doubt that I could have done it without an extra set of hands to hold the belt in place while threading it on the other pulleys. Good to go.
2004 1.8L (1ZZ-FE) Vibe (Lava Red)16" Michelin Destiny tires
