Adding 12V port in the front-center compartment of a 2006
meall
Post by meall »
Hi,As far as I can remember , Vibe's model from 2003 to 2005 had a 12V port into the front-center compartment in between the 2 front seats. The 2006 Vibe don,t have this. I ask my GM garage if that could be added to the 2006, and they could not find a peice for that in their catalog. So far, the guy pointed out that there is a cable there (when you remove the module), but he was not sure it could be used as a 12V plug. The hole is already there in the rear compartment.Any idea on where/how to add this? That may be usefull in camping this summer to plug a refregerated termos.Thanks
Vibe 2008Dark GrayManualElectric group (doors, windows, etc)
Re: Adding 12V port in the front-center compartment of a 2006 (meall)
Is this the thread you were looking for?http://forums.genvibe.com/zerothread?id=13711
Mrizzle05
Re: Adding 12V port in the front-center compartment of a 2006 (joatmon)
Post by Mrizzle05 »
thats wierd... my 05 and fiances 06 had the outlet!!! thats crazy.
orbix
Post by orbix »
Huh. My 50 doesn't have it... I think the change was from the 04 to the 05 model years generally, though there certainly is some variation.
new05vibeowner
Re: (orbix)
Post by new05vibeowner »
My 05 didn't have one either, and the dealer wanted $21 for the part plus installation. Went to Wal-Mart, bought a generic outlet for $5 and wired it myself. Took less than 15 minutes.
Mods: 04 center armrest, 04 Matrix AM/FM/CD/Cassette, Electrochromatic rear view mirror w/compass, GM hood protector, Ventvisors on doors and moonroof, one-touch close moonroof. added 12v outlet in console, Goodyear TripleTred tires, Sirius satellite radio.
meall
Re: (new05vibeowner)
Post by meall »
To wire it yourself, you cut the wire there and solder? what is your method?Thanks
GMJAP
Re: (meall)
Post by GMJAP »
Quote, originally posted by meall »To wire it yourself, you cut the wire there and solder? what is your method?ThanksAs joatmon already posted, please see this thread:http://forums.genvibe.com/zerothread?id=13711It also applies to the 2006.
