hard start problem
Yury
hard start problem
Post by Yury »
Hi , AllWondering if anybody has the same problem.Sometimes after I drive, stop, turn off the engine, let it sit for half an hour or so I have difficulty starting it up again. First time it wouldn't start, i do it again right avay and it starts reluctantly.It starts fine after a night in a cold weather.
07 Accord SE V6.Used to own 05 Base Vibe, it was a nice car
cohocarl
Re: hard start problem (Yury)
Post by cohocarl »
Could be many things. How many miles are on it? If it's still under warranty, I'd swing by the dealer and have them check it, cuz something's "a miss". I never remember having any problems with mine, it always fired right up.
Mase
Post by Mase »
This has been discussed many times.Here's the link to the "Extended Crank" tech service bulletin:http://www.alldata.com/tsb/Toy....html
Re: hard start problem (Mase)
Quote, originally posted by Mase »This has been discussed many times.Here's the link to the "Extended Crank" tech service bulletin:http://www.alldata.com/tsb/Toy....htmlThat works if you have a Toyota, but unfortunately, I don't think that GM has released their version of that TSB yet to cover the Vibe.
Yury
Re: hard start problem (cohocarl)
Post by Yury »
it has about 30 thousand kilometers.dealer said it's that hot soak thing. last time i asked there was nothing no solution from GM.i guess i have to wait for gm to adress this.thanks for replies, guys.
