Hi , AllWondering if anybody has the same problem.Sometimes after I drive, stop, turn off the engine, let it sit for half an hour or so I have difficulty starting it up again. First time it wouldn't start, i do it again right avay and it starts reluctantly.It starts fine after a night in a cold weather.
07 Accord SE V6.Used to own 05 Base Vibe, it was a nice car
Could be many things. How many miles are on it? If it's still under warranty, I'd swing by the dealer and have them check it, cuz something's "a miss". I never remember having any problems with mine, it always fired right up.
Quote, originally posted by Mase »This has been discussed many times.Here's the link to the "Extended Crank" tech service bulletin:http://www.alldata.com/tsb/Toy....htmlThat works if you have a Toyota, but unfortunately, I don't think that GM has released their version of that TSB yet to cover the Vibe.
it has about 30 thousand kilometers.dealer said it's that hot soak thing. last time i asked there was nothing no solution from GM.i guess i have to wait for gm to adress this.thanks for replies, guys.
