Alright guys I'm new here, I have a 2005 Vibe 2wd If I go for 18's with 235-40 R-18's how much can I lower the car, would 1.8F & 2.1R be to much, Thank you ahead of time for reply's
Congrats and Welcome to GenVibe!With 18's the proper tire size is 225/40/18 to maintain oem overall diameter.(assuming the width is 7.5")The drop amounts you have listed should be fine.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
I would think you would be okay, but don't know for sure with the 235 width. I have 18-225/40 tires with the Tein S-tech springs which give about a 2-2.4" drop. My wheels are 8" wide and so I could put 235s on. What size do you have/are getting? 235 would look a little better on my wheels and protect their rims a little more. Anyone else with 235s? The wheel offset can affect this as well, so you might want to look into that as well.Edit: Forgot to mention as Bluecrush did, 235/40/18 will be a larger outside wheel/tire diameter. If you want to try the calculator and check, I wonder if the 235/35/18 size is a better bet.
Justin 2003 Vibe GT - Mille Miglia Evo5 18x8 Wheels (now stock)- Magnaflow Cat-Back Exhaust (now stock)- Tein S-Tech Springs (now stock)- Injen CAI - Red Painted Calipers - Hella Supertone Horns - Polk Speakers - Bazooka RS8A-HP Sub - Kenwood Headunit - Still love my Vibe, but I've just turned it back into a basic daily driver.
dudes, the difference between 225's and 235's is only less .200 per side on the width of the rim. so I wouldn't get him too worked up over the wider tire.
Thanks guys, The Wheel is from MB Motoring/Weapon in Gun-Metal 18x8, Tire is BF/ G-Force Sport 235/40/R-18. I'll get the set up in three days, I post the pics later. Thank you!!
