Installing roof rack bars
arniep
Post by arniep »
I just received a set of the roof rack bars from a group member. Would someone tell me how to install these on a 2005. It appears I must take the front black plastic caps off to allow the rails to slide in, but I don't see the way to do this. I took a hammer out of the equation early on! LOLThanks,Wayne
BlueCrush
Re: Installing roof rack bars (arniep)
Post by BlueCrush »
There is a few how-to's on this site. Just do a search and you'll find it.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Re: Installing roof rack bars (BlueCrush)
Interestingly enough, the service manual says just remove the tightening screws and lift the rails out (or drop in). Needless to say, that is not possible.
arniep
Re: (ragingfish)
Post by arniep »
Who writes those manuals anyway?!!! I'd like to have one of there here when I am working on a car!I found the guide on the site. Not too bad of a job, once you know what to pull hard on without breaking something.Wayne
vibe-anator
Re: (arniep)
Post by vibe-anator »
when you re-installed the end caps, did they fit as tight as when you took them off?Mine are not as tight. did you use the first groove in the yellow button?no what I mean?????
