Would like to know if anyone has had this problem:I notice yesterday in very cold weather (4 degrees) the Sentinals "flicker" on and off when you use the turn signals. Not sure if it has been as cold as it has here. But if it does get this cold where you are look out for this problem. They seems to work fine after the car gets a little warmps. It's 3 degrees this morning so I expect to see the same problem when I leave for work this morning
[Modified by yank dini, 7:17 AM 12/4/2002]
