Twilight Sentinal
yank dini
Twilight Sentinal
Post by yank dini »
Would like to know if anyone has had this problem:I notice yesterday in very cold weather (4 degrees) the Sentinals "flicker" on and off when you use the turn signals. Not sure if it has been as cold as it has here. But if it does get this cold where you are look out for this problem. They seems to work fine after the car gets a little warmps. It's 3 degrees this morning so I expect to see the same problem when I leave for work this morning
[Modified by yank dini, 7:17 AM 12/4/2002]
yank dini
Re: Twilight Sentinal (Salsa!)
Post by yank dini »
quote:It was around -2F yesterday here in Ottawa, but didn't notice this on mine...Are you certain it only happened when your turn signals were activated? Because I suspect that some humidity might also cause this... Breathing in the cold car, would fog windows and the sentinel cover, so it would make the lights go on and off!Positive because it happened again the next day. I just manually turned the lights on to solve the problem.
