Where, physically is the beeper located?
jeffgtx
Post by jeffgtx »
the thing that beep when the keys are in and the door is open and the seat belt isnt on, etc.sounds like its behind the speedo?true?easily accessible or does it require upper dash removal?
JeffGTX's Shades Of Gray Pontiac Armada:Cool: 2008 Solstice GXP ConvertibleSly: 2009 Solstice GXP CoupeMaverick: 2009 G8 GXP
Mase
Re: Where, physically is the beeper located? (jeffgtx)
Post by Mase »
No dash removal necessary.-Pull the entire shroud off the instrument cluster.-Remove the top/center screw.-Undo the 2 clips on the bottom of the cluster.-Pull the cluster out, and unclip the 2 wire harnesses.-Unscrew the rear cluster cover.-You'll see the piezo electric buzzer encased in a big black cylinder.-Pry it off.Attached is a pic, courtesy of WorkinMatrix @ matrixowners.com
It's built into the gauge cluster itself, I do believe. Sounds like you have the same idea I once had. That horrid cheapo radio shack piezo element buzzer thingy has to go! I don't know what those guys were thinking when they designed that. Gimme chimes, dang it! --EDIT-- That above post snuck in while I was coming up with this one... Has anyone successfully installed a different buzzer, such as one that doesn't suck, for instance? Inquiring minds want to know, that damn thing sucks!
jeffgtx
Re: Where, physically is the beeper located? (ColonelPanic)
Post by jeffgtx »
thanks Mase.... dateline saturday... me vs piezo!i took a look at the post on matrix owners. he jsut removed it, he did not replace it.yes CP, you and i are of teh same thought here. that thing hurs my brain.i wanna hook up the voice from mission to mars when the micro meteor goes thru the hull."50% atmosphere" hahahai am gonna go to the parts store and look for replacments tomorrow.
Cool. I'm wondering how that buzzer works - we have 3 different modes basically - the fast beeping for the key, the slower for the seat belt and the steady beep for the lights on warning... Not sure if that is all done in the buzzer assembly itself, or if that is done somewhere else which varies the signal gonig into the buzzer.Definitely would be interesting to see this work out. If it works, I need to find the chime thingy out of a wrecked Hyundai... I don't know why, but that mechanical diiiiing diiiiiiiiiiiiiinnnngg sound is just cool to me. (removed)!
03VibeGT6Spd
Post by 03VibeGT6Spd »
Is that also the Reverse beeper? I wish they would have mounted that one outside the car. LOL
Re: (03VibeGT6Spd)
Yep, I'd say the annoying beep you six speeders have probably comes from the same place. I can't remember what car was being reviewed or where, but I do remember this being said: "It beeps like a forklift when in reverse."
03VibeGT6Spd
Re: (ColonelPanic)
Quote, originally posted by ColonelPanic »Yep, I'd say the annoying beep you six speeders have probably comes from the same place. I can't remember what car was being reviewed or where, but I do remember this being said: "It beeps like a forklift when in reverse." Forklift heck no!It sounds like dumptruck!
Re: (03VibeGT6Spd)
lol! Maybe we'll find a successful mod to eliminate the dump truck action.
Mase
Re: (ColonelPanic)
Post by Mase »
Quote, originally posted by ColonelPanic »lol! Maybe we'll find a successful mod to eliminate the dump truck action. Already done. Cut this red/black wire on your cluster harness [see attached pic]
jeffgtx
Re: (Mase)
Post by jeffgtx »
line the reverse indictor? that may come in handy for my mirror mod.
mcgusto82
Re: (jeffgtx)
Post by mcgusto82 »
why would you guys want to remove that beeper. if it's beeping, something is wrong. once it's fixed, it goes away. if you guys don't like wearing belts... shame on you.
jeffgtx
Re: (mcgusto82)
Post by jeffgtx »
i am not removing, i am replacing with something that doesnt hurt my brain.CP - i am 95% sure teh piezo is not controlling the three beep segments. i cant remember where, but i saw the timing algorythm that put it in teh three timed beep modes, and i dont think that is contained within the little black thing.I'll need to doublecheck that.
Re: (mcgusto82)
Quote, originally posted by mcgusto82 »why would you guys want to remove that beeper. if it's beeping, something is wrong. once it's fixed, it goes away. if you guys don't like wearing belts... shame on you.Thank you for your concern, however removing the buzzer all together does not appear to be the goal of this project, at least from what I can tell. I know I'm not interested in going around and defeating safety features... Instead, I just think that dumping the "piezo crap" buzzer in favor of something a little more pleasant sounding would be a nice project...
mcgusto82
Re: (ColonelPanic)
Post by mcgusto82 »
ohh. well then.. get to work
