What the H**l is holding the Stock speakers in place?
NascarXprt
Post by NascarXprt »
what is holding these speakers in and how do you get them off?
Re: What the H**l is holding the Stock speakers in place? (NascarXprt)
check out http://forums.genvibe.com/zerothread?id=785 looks like rivets that need to be drilled out
Mr. Poopypants
Re: What the H**l is holding the Stock speakers in place? (joatmon)
Post by Mr. Poopypants »
Quote, originally posted by joatmon »check out http://forums.genvibe.com/zerothread?id=785 looks like rivets that need to be drilled outYep, I had to drill mine out. It's not hard to do. Keep in mind that you may have to get speaker brackets for your aftermarket speakers.
Jahntassa
Post by Jahntassa »
Yup, rivets. The rear ones are farily easy to drill out, and most 6.5" speakers can screw directly to the metal in the rear door.The front doors are the same, but I left them in and gutted the speaker so I wouldn't have to get the spacers you'll need to clear the window..
