clutch ques.
Raivis
clutch ques.
Post by Raivis »
how come even though the vibe and matix are so freakin close, the vibe doesn't have the toyota clutch??? the clutch in the matrix/celica is alot smoother
You got owned by a wagon..... Life is a sexually transmitted disease!!! check me out at http://www.myspace.com/raiviskysdad
Re: clutch ques. (Raivis)
I have a base, so I can't say for sure about the GT/XRS, but in the base, the engine/transmission/clutch are exactly the same between Vibe/Matrix/Corolla. I would bet a small piece of money that the clutch is exactly the same between a GT and an XRS. I imagine theres a weight difference between a celica and a Matrix/Vibe that might make a celica seem smoother, but I really wouldn't expect a difference between a GT and an XRS, as long as both were in approximately the same condition.
Jahntassa
Post by Jahntassa »
I think GM cheaped out on the GT stock clutch. I originally ordered a Matrix clutch for my GT, because nobody has the GT part listed, and the center diameter was too small.. So GM might've used a different part, y'know, for fun.
nuttyvibe
Re: (Jahntassa)
Post by nuttyvibe »
So in the end, what clutch did you end up with?
