Software to put records on CD?
Yes, Im talking LP's! Vinyl! Frisbees! Whatever you call them.My mom is a librarian and asked me to convert two records to CD. I figure easy. Just record the record to the PC then burn the disc. No big.Question is -- does anyone know a software program I can use to record a whole side of a record without overflowing memory (i.e. sound recorder would crap out after 1 or 2 songs). Only requirements: minimal interaction from me (so I can other stuff while it records) and must be FREE (or under $15)!!!Thanks!
spoonman
Re: Software to put records on CD? (ragingfish)
Post by spoonman »
Mike,What software do you use to burn your CDs?? I know the Roxio stuff has a program with it that will do what you need. I believe that Nero does as well, but don't hold me to it.... :-)Vern
'04 Monotone Satellite Base Vibe, 5-Spd. w/ ABS, power and M&T Packages
I use goldwave for that kind of stuff, you can record a whole side and then cut it into tracks later
scherry2
Post by scherry2 »
I was told that if you get a cable with 2 rca plugs at 1 end and the plug for your mic jack (plugged in your output on your stereo of course) you can just save the audio signal as a wave file then just convert it to whatever you want to when you burn it.Never tried it though.
I am using an RCA to standard headphone plug to get the sound into the PC. I then use Roxio Spin Doctor (part of ECDC) to record it. It's the breaking up and editing I'm not finding the software capable of doing...I'll try Goldwave, thanks Joat!
Thanks for the tip Joatmon!GoldWave works fantastically!I knew you guys wouldn't let me down!
spoonman
Re: (ragingfish)
Post by spoonman »
Quote, originally posted by ragingfish »I am using an RCA to standard headphone plug to get the sound into the PC. I then use Roxio Spin Doctor (part of ECDC) to record it. It's the breaking up and editing I'm not finding the software capable of doing...I'll try Goldwave, thanks Joat!Interesting..... I know my grandpa uses the Spin Dr. program to record both his vinyl collection and his reel to reel tapes..... Oh well.... I will have to tell him about the Goldwave too.
Yeah, ECDC comes with a sound editor, but it vomits any time I try to take a large file and cut it up...plus it's completely stripped of any half-decent features.
spoonman
Re: (ragingfish)
Post by spoonman »
Quote, originally posted by ragingfish »Yeah, ECDC comes with a sound editor, but it vomits any time I try to take a large file and cut it up...plus it's completely stripped of any half-decent features.Yeah... I know it isn't the best thing out there..... But you did mention free..... good luck with the project!Vern
