Overhead light not activated when front right door is open
Vibespread Panic
Post by Vibespread Panic »
Anyone had probs w/ this or is it a normal function? The only question is, why does it turn on when you open every other door?
'03 Abyss Vibe GT6-speedfront, rear faciaground effectsroof spoilergate spoilermoon & tunesjust lookin' to get faster!
Re: Overhead light not activated when front right door is open (Vibespread Panic)
Funky switch.Dealer repair.
I remember someone having that problem when it was really cold. when you open that door, does it look like the switch in the door jamb sticks out like it's supposed to or is it still compressed like it would be if the door was shut? (might have to compare it to the one on the driver door)
Jahntassa
Post by Jahntassa »
Yeah, if it's only the one door..it's probably the door switch..
Mavrik
Re: (Jahntassa)
Post by Mavrik »
yup, winter tends to do things to cars that can't be prevented at your dealership... like frozen washer nozzles even with -40 in the tank, stuck locks and doors, wipers damaged due to turn on with blades frozen to window.. and sticking door jam switches.I'm going to say try heating that door area up around the switch, see if when you open the door if it is popping back out, if not its stuck.
fjf511
Post by fjf511 »
I have found on mine that if any of the doors are not absolutely tight the light comes on.
04 ABYSS AWDM & TPOWER PACKAGEWINDOW TINT
Mavrik
Re: Overhead light not activated when front right door is open (fjf511)
Post by Mavrik »
yeah you really need to slam that trunk hatch.
ToolGuy
Post by ToolGuy »
If it is broken and you can use a screw driver, you can replace it on your own. Forget the dealer... Unless it is under warranty.Here is the procedure...1) Remove the one mounting bolt and pull the switch (1) from the door jamb. 2) Disconnect the front door jamb switch electrical connector. 3) Remove the door jamb switch (1) from the vehicle.
Vibespread Panic
thanks, I think I'll take it in (still under factory warranty)
sylvainber
Re: (Vibespread Panic)
Post by sylvainber »
on that note... does anyone know if an aftermarket dome light unit could be installed to replace the stock, one that would have reading lights built in?i have a base, no moon roof and it's a shame they didn't put reading lights... sylvain
Salsa 2-tone Basecargo nets, liner and seatback storageThe best thing about having my previous car totaled in an accident is that i got a Vibe to replace it
Re: (sylvainber)
anything scan be done with time, money and the right tools
sylvainber
Re: (ragingfish)
i think i just struck out... loli'll check with the local mod shops
ToolGuy
Re: (sylvainber)
Post by ToolGuy »
Quote, originally posted by sylvainber »on that note... does anyone know if an aftermarket dome light unit could be installed to replace the stock, one that would have reading lights built in?i have a base, no moon roof and it's a shame they didn't put reading lights... sylvainCheck eBay lots sold on there... Very easy hook up and you can get a good deal there.
