I remember someone having that problem when it was really cold. when you open that door, does it look like the switch in the door jamb sticks out like it's supposed to or is it still compressed like it would be if the door was shut? (might have to compare it to the one on the driver door)
Yeah, if it's only the one door..it's probably the door switch..
yup, winter tends to do things to cars that can't be prevented at your dealership... like frozen washer nozzles even with -40 in the tank, stuck locks and doors, wipers damaged due to turn on with blades frozen to window.. and sticking door jam switches.I'm going to say try heating that door area up around the switch, see if when you open the door if it is popping back out, if not its stuck.
If it is broken and you can use a screw driver, you can replace it on your own. Forget the dealer... Unless it is under warranty.Here is the procedure...1) Remove the one mounting bolt and pull the switch (1) from the door jamb. 2) Disconnect the front door jamb switch electrical connector. 3) Remove the door jamb switch (1) from the vehicle.
on that note... does anyone know if an aftermarket dome light unit could be installed to replace the stock, one that would have reading lights built in?i have a base, no moon roof and it's a shame they didn't put reading lights... sylvain
Salsa 2-tone Basecargo nets, liner and seatback storageThe best thing about having my previous car totaled in an accident is that i got a Vibe to replace it
i think i just struck out... loli'll check with the local mod shops
Quote, originally posted by sylvainber »on that note... does anyone know if an aftermarket dome light unit could be installed to replace the stock, one that would have reading lights built in?i have a base, no moon roof and it's a shame they didn't put reading lights... sylvainCheck eBay lots sold on there... Very easy hook up and you can get a good deal there.
