i have 2 Queastions
Vibe_dude
i have 2 Queastions
Post by Vibe_dude »
#1 is the base 1.8 l a single or double over head cam.........a buddy asked me and i was not sure.#2 what is the best spark plug out there that u guys are useing...ngk iridium?
Jahntassa
Post by Jahntassa »
#1) Single on the Base model#2) I believe most people are using the stock plugs, which are Iridium if i'm not mistaken.
ToolGuy
Re: i have 2 Queastions (Vibe_dude)
Post by ToolGuy »
Stick with the stock plugs. If not, you could open yourself up to issues besides, you will not feel a difference with different plugs.
drunkenmaxx
Re: i have 2 Queastions (MiVibe-ToolGuy)
Post by drunkenmaxx »
call me crazy, but im pretty sure the base has a dual overhead cam.
Jahntassa
Re: i have 2 Queastions (drunkenvibe)
Post by Jahntassa »
Quote, originally posted by drunkenvibe »call me crazy, but im pretty sure the base has a dual overhead cam. I had the understanding it was a single with variable valve timing..and the GT was the dual (hence the lift, like VTEC). I could be wrong though... Anyone with the definitive answer?
ToolGuy
Re: i have 2 Queastions (Jahntassa)
Post by ToolGuy »
Vibe — 130 hp 1.8L DOHC VVT-i Vibe GT — 170 hp 1.8L DOHC VVTL-i Vibe AWD — 123 hp 1.8L DOHC VVT-i Sorry... Taken from the Pont site.
Atomb
Post by Atomb »
i don't think it would be possible to have 4 valves/cylinder and only a SOHC?any SOHC (i.e VW) are 2 valves per cyl.
Vibe_dude
Post by Vibe_dude »
i just found out from the toyota and pontiac websites that they are all dohc's....well know that i have that all cleared up i can sleep now.lol
Re: (Atomb)
Quote, originally posted by Atomb »i don't think it would be possible to have 4 valves/cylinder and only a SOHC?any SOHC (i.e VW) are 2 valves per cyl.Indeed, most of 'em are... Only exception I can think of off the top of my head was Hyundai's Alpha engine from a few years back - there was a SOHC 12-valve version...The Vibe definitely has two cams, the service manager commented about my noisy engine, pointing out that there is a lot going on inside that thing. And there is, when comparing the 1ZZ to a native GM powerplant, I suppose.
futseal04
Re: (Atomb)
Post by futseal04 »
Quote, originally posted by Atomb »i don't think it would be possible to have 4 valves/cylinder and only a SOHC?any SOHC (i.e VW) are 2 valves per cyl.Some of Honda's V6's are SOHC 4 valvers, the new F150 and Mustang V8's are SOHC 3 valvers, and I think that most Benz V6's are SOHC 3 valvers as well. If that isn't confusing enough, a lot of 4 valve diesels are pushrod driven!
'04 Vibe Base'97 Buick Riviera S/C'01 Suzuki SV650S
5lbsofswisscheese
Post by 5lbsofswisscheese »
My brother's '95 Neon has a SOHC, 16-valve engine. I did a double-take upon seeing that; I was like, "That must be a f***d-up looking, really crowded camshaft," or something like that.
2004 Fusion Vibe GTMoon & Tunes, 6-CD changer, 17" Wheels, Power Package35% tint17"x7" Enkei 5+ wheels, 215/50/R17 Fuzion Zri tires(Goodbye to the old '03 Neptune GT! I'll always have the radio to remember it by.)
polaris1000
Post by polaris1000 »
Quote, originally posted by MiVibe-ToolGuy »Stick with the stock plugs. If not, you could open yourself up to issues besides, you will not feel a difference with different plugs. I would of thought the same, but I decided to try out some Denso Iridium Spark Plugs. This was before I put on my exhaust and intake and I could sure feel the difference. The engine seemed more torquey and seemed to help through 4000-5500 range in the rpm's.I did not notice a difference in MPG'S, but I have never been one to watch my MPG'S. I would say they are worth the money and I have not had any problems for over 9 months+++
http://members.cardomain.com/pontiacvibegt MagnaFlow Cat-back Exhaust Injen CAI TRD Lowering Springs TRD Ground Wires TRD Strut Tower Brace Progress Rear Sway Bar E.S. Motor Mounts
Turbo5Speed
Re: i have 2 Queastions (polaris1000)
Post by Turbo5Speed »
Boshe Platinum series are dependable plugs as well. Ground wires will also helping by grounding at the most efficient points. Also, check out MSD Ignition ( http://www.msdignition.com/ ) for other electrical AM parts to fit your needs.
