#1 is the base 1.8 l a single or double over head cam.........a buddy asked me and i was not sure.#2 what is the best spark plug out there that u guys are useing...ngk iridium?
LOVE THAT VIBE 2003 Satilite Silver auto.......188,000kms.2006 Chevrolet Trailblazer White 4.2 Inline 6 291hp auto.........156,000kms.
#1) Single on the Base model#2) I believe most people are using the stock plugs, which are Iridium if i'm not mistaken.
Quote, originally posted by drunkenvibe »call me crazy, but im pretty sure the base has a dual overhead cam. I had the understanding it was a single with variable valve timing..and the GT was the dual (hence the lift, like VTEC). I could be wrong though... Anyone with the definitive answer?
Quote, originally posted by Atomb »i don't think it would be possible to have 4 valves/cylinder and only a SOHC?any SOHC (i.e VW) are 2 valves per cyl.Indeed, most of 'em are... Only exception I can think of off the top of my head was Hyundai's Alpha engine from a few years back - there was a SOHC 12-valve version...The Vibe definitely has two cams, the service manager commented about my noisy engine, pointing out that there is a lot going on inside that thing. And there is, when comparing the 1ZZ to a native GM powerplant, I suppose.
Quote, originally posted by Atomb »i don't think it would be possible to have 4 valves/cylinder and only a SOHC?any SOHC (i.e VW) are 2 valves per cyl.Some of Honda's V6's are SOHC 4 valvers, the new F150 and Mustang V8's are SOHC 3 valvers, and I think that most Benz V6's are SOHC 3 valvers as well. If that isn't confusing enough, a lot of 4 valve diesels are pushrod driven!
My brother's '95 Neon has a SOHC, 16-valve engine. I did a double-take upon seeing that; I was like, "That must be a f***d-up looking, really crowded camshaft," or something like that.
2004 Fusion Vibe GTMoon & Tunes, 6-CD changer, 17" Wheels, Power Package35% tint17"x7" Enkei 5+ wheels, 215/50/R17 Fuzion Zri tires(Goodbye to the old '03 Neptune GT! I'll always have the radio to remember it by.)
Quote, originally posted by MiVibe-ToolGuy »Stick with the stock plugs. If not, you could open yourself up to issues besides, you will not feel a difference with different plugs. I would of thought the same, but I decided to try out some Denso Iridium Spark Plugs. This was before I put on my exhaust and intake and I could sure feel the difference. The engine seemed more torquey and seemed to help through 4000-5500 range in the rpm's.I did not notice a difference in MPG'S, but I have never been one to watch my MPG'S. I would say they are worth the money and I have not had any problems for over 9 months+++
http://members.cardomain.com/pontiacvibegt MagnaFlow Cat-back Exhaust Injen CAI TRD Lowering Springs TRD Ground Wires TRD Strut Tower Brace Progress Rear Sway Bar E.S. Motor Mounts
Boshe Platinum series are dependable plugs as well. Ground wires will also helping by grounding at the most efficient points. Also, check out MSD Ignition ( http://www.msdignition.com/ ) for other electrical AM parts to fit your needs.
