Armrest Extension?
bjlarson
Armrest Extension?
Post by bjlarson »
Does anyone know if there is an aftermarket armrest extension available?Thanks,Brian
2005 Vibe AWDMonotone Neptune BlueMoon & TunesK&N FilterchargerDynomax ST MufflerWish List: Unichip
Merzbow
Re: Armrest Extension? (bjlarson)
Post by Merzbow »
build one;)
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
GMJAP
Post by GMJAP »
What do you mean by armrest extension?
bjlarson
Post by bjlarson »
You know, the center armrest with the storage. By extension, I mean to increase it in height, for it is too low.
JohnC
Post by JohnC »
My daughter made me a little pillow that sits on top of the armrest...works great. I use on in most of the vehicles I drive, seems like engineers design the armrest for short people only.
The armrest height is ok for me. What's your seat height? If you lower the drivers seat, the armrest is relatively higher.How much do you want to raise the armrest?
Raven
Re: Armrest Extension? (joatmon)
Post by Raven »
It's a good height for me too. I drive with the seat in it's lowest position. If you want to see a low armrest, sit in an '05 Vibe. When I got in, I leaned towards my right elbow as I always do and almost fell over into the passenger seat.
GMJAP
Post by GMJAP »
Quote, originally posted by bjlarson »Does anyone know if there is an aftermarket armrest extension available?Don't know of an aftermarket extension, but per the thread below, you can get & put in the higher armrest with storage tray (like in earlier models)http://forums.genvibe.com/zerothread?id=12602
Raven
Re: Armrest Extension? (GMJAP)
Post by Raven »
That was definitely a mistake to delete the extra storage compartment on the '05s but they have a much improved seat height adjustment. Instead of the big knob on the side , they have a lever. Pull up to raise and push down to lower. It even works when you are sitting in the seat!
Sputnik
Post by Sputnik »
Quote, originally posted by bjlarson »Does anyone know if there is an aftermarket armrest extension available?Thanks,BrianYeah do what we do - buy 4 baseboards 5/8th of an inch thick and run them up through the centre! I had my arm resting on them all the way home!
GenVibe Global Moderator
bjlarson
Post by bjlarson »
That would work perfect. I prefer to sit a little higher. So it makes the cente armrest even lower. The higher armrest with the extra storage tray would be perfect. Thank for the tip.Brian
