How to link laptop and desktop?
wicked1981
Post by wicked1981 »
Ok so my brother just bought a new laptop and he called me to ask how does he get his files from his laptop to his desktop. I know what you are thinking floppy or disk but he has tons and tons of school work that would take a long time to put on disk and transfer. My question is how do you link the two? I know its with a cable but is it a usb cable or is it a diffeent "special" cable to link them? I dont have the laptop here so I cant look at it I know its an HP w/Intel 4. Thanks.
Mr. Poopypants
Re: How to link laptop and desktop? (wicked1981)
Post by Mr. Poopypants »
If both computers have a network card, all you have to do is get a crossover cable (looks like a cat5 patch cable but is different), if the laptop has XP it should recognize that it is connected to another computer.
Mr. Poopypants
Re: How to link laptop and desktop? (desert_dweller)
This is true, but if you don't have either, the crossover is cheap.
ebslopp
Re: How to link laptop and desktop? (Mr. Poopypants)
Post by ebslopp »
or he could open a yahoo account and get 100mb of space in email and like 25mb in yahoo briefcase. upload the files he needs and then download them onto the desktop.
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
Mr. Poopypants
Good point.
ebslopp
Post by ebslopp »
Quote, originally posted by desert_dweller »But half the fun is buy more stuff than you need to get the job done This is true!
ragingfish
Post by ragingfish »
How about a Zip drive?Buy one of the external versions...then you can just flop it back and forth between the two machines...But I agree with what was said above - a Cat 5 crossover is your best bet!
2009 PONTIAC G8
ebslopp
Re: (ragingfish)
Post by ebslopp »
If you're going to buy new equipment to swap files, you might as well go all out. Buy yourself a wireless card for the laptop and a wireless router. Now connect the desktop to the wireless router via a cat5 cable and set up the notebook on the wireless network. Now you can swap files/game/search the internet from anywhere in your house!
Winter
Post by Winter »
Mr. Poopypants is the only one who ISN'T complicating things more than they need to be. Yes, you have multiple options, but all you need is a crossover cat5 cable which costs $3 at BestBuy (even cheaper at small computer shops). Any Windows OS will automatically recognize it and you can transfer at up to 10mb/s, even if you don't have a broadband internet connection.The second-most popular option is to just burn CD's. You can store 700mb on the avg CD so even 2 gigs of data would only take 3 CD's. Zip drives are out of the question as they are antiquated and some stores no longer sell them. A router or switch is sometimes a pain for a n00b to setup and completely pointless unless you want both boxes to have simultaneous internet access. ...and most people stopped reading this about 6 sentences ago anyway so I'll just shut up now.
Mine: '03 Aztek GT, Liquid Gray monotone fully loadedWife: '04 Vibe base, Neptune two-tone w/ power pkgReal men drive a Pontiac.
wicked1981
Re: (Winter)
Quote, originally posted by Winter »and most people stopped reading this about 6 sentences ago anyway so I'll just shut up now. LOL!! Thanks for all the help!!
wicked1981
Re: (wicked1981)
Ok so I have the laptop connected to my comp right now but its not dtecting it..... Is there something manual I have to do or can do? Im running XP and so is the laptop so what am I missing here?
Mr. Poopypants
Re: (wicked1981)
You have to share out the folders you want to move, make sure you server service is on and the file and print sharing option is on on the computer that you want to transfer the files from. On the computer that you are transferring the files to, you need to map the shared folders. For example the computer that you are pulling the files off of will be COMPUTER A and the computer that will receive the files will be COMPUTER B. On COMPUTER A, go to start>control panel>performance and maintenance>administrative tools>services scroll down to Server service, if it is not started, start it. Close out of that screen, go to Start>Control panel>network connections, double click on the LAN connection that should be present because of the crossover connection. It will open a small window, click on properties and make sure that File and Print Sharing is turned on (checked). Next, go to the folder you want to share, right click on it and select Sharing. Name the folder whatever you want, for example TRANSFER1. After you do this you will need to find the actual name of the computer. Right click on the My computer icon and select properties, on the computer name tab you will see the computer name. For example we will still use COMPUTER A. NOW go to computer B, right click on the My computer icon and select "Map network drive" Leave the drive letter alone and in the folder box type the following using the names of your computer and the shared folderCOMPUTER ATRANSFER1it will open the folder from the other computer, from there, you can drag and drop or copy and paste everything you need.Hope this helps, I'm such a nerd.
wicked1981
Re: (Mr. Poopypants)
Quote, originally posted by Mr. Poopypants »Hope this helps, I'm such a nerd. Hey computers are here to stay the more you know the better. Wish I knew a little more. I know a little more than average but not enough.
