Aem Pulleys
rcasciola
Aem Pulleys
Post by rcasciola »
has anyone installed the aem pulleys on their vibe/trix? and if so had any poblems...
My Car, with the kit on. it looks awesome! come and check it out, tell me what u think.P.S. the gray will be painted momentarily http://www.cardomain.com/ride/514882/1
Evanshall
Post by Evanshall »
theres been problems with cosmo pulleys i think, AEM though i havnt heard good or bad about, there supposed to be good, but as well there was a problem with atleast the other pulleys that caused oil pumps to shatter(not good at all), i would do more research around myself read reviews for even other cars as every little but helps
goodvibe
Re: (Evanshall)
Post by goodvibe »
AEM don't supply a crank pulley so it ahouldn't be dangerous. Not much gain though.
wicked1981
Re: Aem Pulleys (rcasciola)
Post by wicked1981 »
Don't get pulleys unless you can pay for a new engine. http://forums.genvibe.com/zerothread?id ... ad?id=8512
goodvibe
Re: Aem Pulleys (wicked1981)
Post by goodvibe »
Only the crank pulley can cause the imbalance/vibration problem. Accessory pulleys aren't an issue. AEM doesn't supply the crank pulley. Check your second (earlier) link. I brought it up. Got it from the Celica forums.
Flip-Side
Post by Flip-Side »
I don't think the AEM pulleys are worth it. Only tiny amounts of power can be gained from changing the alternator pulley. They are just for looks in my opinion.I was looking at underdrive pulleys, but decided against possibly destroying my vibe. Thanks to some people here for educating me.
Stang2Vibe
Re: Aem Pulleys
Post by Stang2Vibe »
The problem with the aftermarket pulleys is that they lack a harmonic balancer on the crank pulley. That is what was causing the oil pump to shatter which in turn caused the engine to fail. I would also imagine that a poorly balanced accessory pulley can cause premature wear on the bearings in that accessory, though.
goodvibe
Re: Aem Pulleys (Stang2Vibe)
Post by goodvibe »
The accessory pulleys don't have balancers and are lighter than stock so that any effect of machining errors would be reduced over stock. Again, I don't think they are worth the effort unless you like the pretty colors. The crank pulley also effects the crank bearings but the oil pump is the first to go. It may be related as the pump is driven off the crank.
