Oil Filter
wildvibe
Oil Filter
Post by wildvibe »
I changed my oil today woot woot! Mobil One with a PH3614 Fram filter. Was weird though because the old filter the dealership used was an AC Delco and the seating on it was smaller. Wonder if the dealership was putting on the wrong oil filter. I don't know what the model number on it was cause its covered in oil but I do find it strange usually they should be the same size!
2003 Abyss Vibe GTMoon & Tones PackagePower Package Mods: -Freedom Design Front Strut Bar-Window Tint 20% Sides and Back %35 on Driver and Passenger Door Future Upgrades: -Underdrive Crank Pulley-Borla Catback Exhaust-Injen CAI-ACT Xtreme Clutch Kit w/ 6-Puck Race Disc (Torque Capacity 351 ft.lbs.)-18" Katana - KR-7 (HyperBlack)-Eibach Springs
michaelgt
Re: Oil Filter (wildvibe)
Post by michaelgt »
There is a Mobile 1 filter. It is the M1-103. I used it and Mobile 1 in my oil change on Sunday. I love doing oil changes in the Vibe. Nothing in the way! Different story for the Yukon XL. I burn my hand on the exhaust and run oil all over the Ujoints and drive shaft.
wildvibe
Re: Oil Filter (silverawd26)
Post by wildvibe »
lol! My wifes car isn't that bad to change as your Yukon XL but its still a pain in the ahole (Pontiac Grand AM hunk of junk)
ragingfish
Re: Oil Filter
Post by ragingfish »
This is the first car I've ever done my own oil on...the first time I did it with a jack and stands...but decided getting them under there was way more trouble than it's worth...so next time around I'm gonna give it a shot as is...But with the stands, it was very easy to find the filter and drain plug...so I don't expect any troubles with my next change...Except for maybe taking it to be recycled without it staining my car again...
2009 PONTIAC G8
Pawel
Re: Oil Filter (michaelgt)
Post by Pawel »
quote:There is a Mobile 1 filter. It is the M1-103. I used it and Mobile 1 in my oil change on Sunday. I love doing oil changes in the Vibe. Nothing in the way! Different story for the Yukon XL. I burn my hand on the exhaust and run oil all over the Ujoints and drive shaft.Is this the full part #? I'm asking cause I would like to use Mobil 1 filter with my Mobil 1 oil.
2003 VIBE GT ABYSSMODS:AEM CAI PHILIPS BLUEVISION
ken
Re: Oil Filter (Pawel)
Post by ken »
my dealer uses the ac delco filter as well. from the little research i've done, it's a pretty good filter. can't say the same for the fram. do a search on the net on fram filters. hopefully they have improved on their product.
viberations
Post by viberations »
the oil filter i suggest is what came on the car, which in my case it wasa toyota filter, ive used it since i had the car new and they havebeen great, and a hell of alot cheaper than gm partsgm>
PJV TOYOTA DEALER ROCHESTER N.Y
johnsoax
Re: Oil Filter (viberations)
Post by johnsoax »
Here's a question. Why does Fram specify the same filter for Vibe GT and 2001 Neon, but Purolator is different?I just changed the oil in my wife's Neon last night and I am thinking that maybe I won't use Fram anymore (even though I've used it for years). I'm driving to Florida next month (from Chicago) in the Vibe and I am worried about the Fram driving down and back (2500 miles). I do oil changes every 5000 miles because I drive mainly toward the "light" schedual than the "heavy" schedual.
Stereo Mod - Cargo carpet - Phone on ash tray. - Hidden HitchProjects: Fix CELMileage - 50050 - 31.41 MPG Ave
DavidPIL
Post by DavidPIL »
Hey, I had a Ranger too.. Though it was a 97. Was very easy to change the Oil on as well. I did however drive the truck up on 2x8's laid flat to give me a bit more clearance. I may try that with the Vibe as well. I can tell that will be just as easy since you can see everything clearly with nothing in the way. Dave
DavidPIL
Post by DavidPIL »
quote:There is a Mobile 1 filter. It is the M1-103. I used it and Mobile 1 in my oil change on Sunday. I love doing oil changes in the Vibe. Nothing in the way! Different story for the Yukon XL. I burn my hand on the exhaust and run oil all over the Ujoints and drive shaft.I did some research and found that the M1-103 filter isn't the right filter. I was confused because when I went to Auto-Zone to get a filter, the M1-103 was smaller than the Fram PH3614 filter which is for the GT. Since Auto-Zone didn't have a parts list book that contained the VibeGT (though they did have other '03 models), I found that the M1-102 cross-references with the Fram which is also in their computers as being the right Mobil Oil filter for the GT. The M1-103 seems to be for the Base model. Dave
Pawel
Re: Oil Filter (DavidPIL)
Post by Pawel »
M1-103 fits GT. What's what my baby usues.
ragingfish
Re: Oil Filter
Toyota filter here.And after spilling craploads of dirty oil on the garage floor at the last change, and the rapid onset of colder weather, I think I may go back to having someone else do it...Argh!
2009 PONTIAC G8
Hot Vibe
Re: Oil Filter (ragingfish)
Post by Hot Vibe »
To make things easier on your self use jack stands and spread them out to give yourself plenty of space to work. Do not worry about using a filter wrench. Use chanel locks and slowly turn the filter off then put it in the pan. Then remove the plug. First remove the cap on the engine and pull the dipstick out. This will prevent splatting and enable a smooth flow. Go out and invest in the $15 pan that has handles and the spout to pour. It will be worth every penny if you are a novice.
Just here to lend a hand to people who have questions about their Vibe.
ragingfish
Re: Oil Filter (Hot Vibe)
I use that pan already...but it doesn't help if you miss the entire pan!
2009 PONTIAC G8
Hot Vibe
Post by Hot Vibe »
quote:I use that pan already...but it doesn't help if you miss the entire pan! LOL fish you just either like to color the garage floor. Save those coupons you get in the mail. Actually what you should discuss with one of those oil changing places is how much would they charge if you had your own oil and filter? $5-10 labor might be worth it.
DavidPIL
Post by DavidPIL »
OK, the Fram 4967 cross-references to the Mobil M1-103, right? This one is in the books at Auto-zone as being the one for the 1zz and 2zz Celica engines (Because they don't have the Vibe or Matrix in there yet).The Filter recommended on here is the Fram 3614 which cross-references to the Mobil M1-102. This is the Filter that the Wal-Mart filter book thingie recommends for the 2zz engine.THere is a sizeable difference between the 2. I do understand that one engine has more oil in it than the other but why does my service tech tell me the 3615 and M1-102 are both too big for my VibeGT and then proceeds to put a small delco filter in which is the same size as the Fram 4967 ?Shouldn't my service tech know what filter to put on? Why are basic parts so difficult to locate and to verify?!?!?! Someone tell me what's correct, pleeeeeze!!!Dave
Hot Vibe
Post by Hot Vibe »
The AC Delco part number is the same for both engines. Anyone who tells you any different needs to come see me here at SPO headquarters so I can kick them in the nads. #PF1233 DURAGUARD fits all three SN=GT, SL=Base, SM=AWD vehicles.
NovaResource
Post by NovaResource »
quote:Someone tell me what's correct, pleeeeeze!!!There are only 3 things that really matter when it comes to correct fitting oil filters:1 - the diameter if the filter gasket is the same as the diameter of the sealing surface on the block. This is to make sure the filter seals and does not leak.2 - the thread size of the filter is the same as the thread on the block. This is to make sure the filter stays on.3 - it has the minimum filtering capacity for the engine.Other than that, it's doesn't mater what the number on the filter is. As long as there is physical room for the filter in the engine compartment, a larger filter can be used along with the extra oil to get a proper oil level.For years I used the "wrong" PF52 filter on my old '93 Sunbird (PF47 was the correct one) because it was about 50% longer. Same for my Nova. I use the longer PF35 instead of the "correct" PF25.Since the blocks of the 1ZZ and 2ZZ engines are basically the same, the 1ZZ filter can be used on the 2ZZ engine and vice versa. If you can find a longer one then by all means, use it. Just be sure the oil level is correct after the filter is filled.
Raptor-vibes
Re: Oil Filter (ken)
Post by Raptor-vibes »
For those who are wondering about FRAM filters the new Fram X2 series are the best, matching K&N filters and even having higher filtration. If you use engine treatments,(Which you should avoid using for the first 50,000Km/35,000Mil,) to help protect during the time between starting and when the oil gets to the parts. The reeason is that most filters alow the oil to return to the pan. The new FRAM filters have a one way check valve which keeps the oil in the gallies not in the pan which means as soon as you start your engine the oil is right there. Use Castrol or any full syntheic 5W50 oil and you'll never have a problem. My 98 Cavalier after 6 years the oil still comes out golden at each 7,000Km change even after 180,000kms on her!
My 2004 Is One Mean Vibe!!!!!
coratz
Re: Oil Filter (Raptor-vibes)
Post by coratz »
hey any of you guys that do your own oil worry about marking up your frame rails/underbody? i use blocks of wood under my jackstands/floor jack but i still manage to dent it up!!!! anyone got any idea other than jack your car up slower? my wife just does not think a lift is a worthwhile expense right now.
Kissfan79
Re: Oil Filter (coratz)
Post by Kissfan79 »
If you are just changing your oil and have not lowered your Vibe you won't need a lift or jack to change your oil. I have changed mine several times now. Just lie flat on your back and you should be able to slide far enough under the front end to reach the plug and filter.Jim
Abyss Vibe GT monotoneMoon & Tunes w/6 disc changerCargo nets and mat93 Octane w/ lots o' KISS in the CD changer
Hot Vibe
Re: Oil Filter (Kissfan79)
Post by Hot Vibe »
quote:If you are just changing your oil and have not lowered your Vibe you won't need a lift or jack to change your oil. I have changed mine several times now. Just lie flat on your back and you should be able to slide far enough under the front end to reach the plug and filter.Jim For those of you without beer guts. Oh yeah over 6ft tall as well.
Kissfan79
Post by Kissfan79 »
LOL...well...I do have a bit of gut right now (haven't worked out in a looog time) and I am about 6'. Give it a try....you don't have to get all the way under iit...just close enough to reach the plug with your hand.Jim
geezer
Post by geezer »
I'm definately in the "does not fit under the car" catagory. Rather than bothering with jacking up the car and using jack stands, etc., I long ago invested in a set of Rhino ramps. I think they're still about $27 at Walmart or O'Reileys. They raise the vehicle about 7-1/2" or so.
XRS 6-speed, Cosmic Blue, 17's, AEM Short Ram, Hidden Hitch
johnsoax
Re: Oil Filter (geezer)
Post by johnsoax »
Just did an oil change last night and noticed that the Purolator L14477 filter on my GT was leaking. I put it on tight and it was hard to get off, so I am wondering if anyone else has had a problem with it. I put another one on and really cranked it down (by hand), maybe an extra 3/4 -1 turn. I'm sure that it will be a pain to get it back off .If this one leaks (will check it in about 1000 miles) I will have to change filters yet again. Maybe I'll just go back to using fram filters.
Hot Vibe
Re: Oil Filter (johnsoax)
Post by Hot Vibe »
Did it leak enough to coat the undercarriage?
johnsoax
Post by johnsoax »
No, there were just a couple of drips down the sides of the filter. It didn't leak much, because the dipstick still said pretty close to full.Maybe, now you've got me paranoid. No, I even checked the driveway and garage and no oil stains, so it wasn't leaking more than a few little drips running down the filter.
Hot Vibe
Post by Hot Vibe »
A couple of drips could just happen while the seal of the filter closes as the temp rises. It sounds like you may not have put enough oil on the seal before you put the new one on the vehicle. It happens and not to worry. The filter did its job by getting some oil once your pump started working and sealed itself.
johnsoax
Post by johnsoax »
I'm wondering if I forgot to do that last time. I thought the same thing and made sure that I put a good coat on this time. I've changed the oil 4 times, 2097, 5230, 11134 and 15665. The first two were with Fram filters and the last two with Purolator filters. All have been with Quaker State oil. Everything seems fine, except that little bit of oil on the filter.
Kissfan79
Post by Kissfan79 »
I use the exact same filter on my GT and have not had any problems with it. The reason I like this filter is the fact that it is a bit larger than the other filters available. I tighten mine by hand as well. I don't really "crank down" on it. When it's time to change my oil, I can still loosten it and remove it by hand with no problems.Jim
DavidPIL
Post by DavidPIL »
Well I finally did my own oil change... I got tired of service people telling me one thing then hearing what seem to be more logical here so I tried a few things myself... and this is what I did...I removed the Delco Filter which, btw, leaked oil all over me. Someone had posted that nothing leaks out of the filter area when removing... Well, maybe I should drained the pan first... oopsie... Anywho, I know the Fram 4967 is the appropriate replacement filter for the OEM delco which also corresponds to the M1 103 from Mobil, well, I found a Fram 4386 which has the same footprint as the Delco but about 3/4 of an inch longer. I read somewhere that a longer filter is better so I went with it. In the process I tried my M1-102 which I had bought some time ago and then the service man told me it wouldn't fit, showing me the different footprints... Well, it did fit though the metal lip was just outside the seat, the gasket was full on the seat. I ended up using the Fram 4386 because I didn't have the right filter wrench for the M1-102...Dave
ebslopp
Post by ebslopp »
Wow is that oil filter small!!! My Civic with a 1.5 has a bigger oil filter than the 3967. Has anybody tried a larger filter? If so, have you noticed a difference in how dirty your oil is?
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
DavidPIL
Re: (ebslopp)
Post by DavidPIL »
hi ebslopp,I have the GT, & was using the Fram 4967 model of filter which was dinky.... A bit smaller than the Purolater 14477. I used a slightly longer Fram 2 oil changes ago... Don't remember the number. This last time I decided to use a Mobil M1 filter... Not the 103 which is recommended but the 102 which is both wider and longer. The filter gasket just fits. Have driven about 1000 miles so far without any leaks. Will either continue with the Mobil M1-102 or will switch to the K&N equivalent, which is the HP-1002.Dave
themrfreeze
Re: (DavidPIL)
Post by themrfreeze »
Anybody care to recommend a good place online to buy the Toyota filter for the base model Vibe (Toyota part number 90915-YZZA2)? I've been changing oil in my cars long enough to know that OEM filters are the way to go, but I hate buying them at inflated dealership prices.Thanks!
mkosem
Post by mkosem »
Quote, originally posted by Raptor-vibes »For those who are wondering about FRAM filters the new Fram X2 series are the best, matching K&N filters and even having higher filtration. If you use engine treatments,(Which you should avoid using for the first 50,000Km/35,000Mil,) to help protect during the time between starting and when the oil gets to the parts. The reeason is that most filters alow the oil to return to the pan. The new FRAM filters have a one way check valve which keeps the oil in the gallies not in the pan which means as soon as you start your engine the oil is right there. Use Castrol or any full syntheic 5W50 oil and you'll never have a problem. My 98 Cavalier after 6 years the oil still comes out golden at each 7,000Km change even after 180,000kms on her! A filter that "allows the oil to return to the pan" is not correct for our cars and should not be used. Any filter you see that is recommended for use will have an anti-drainback valve(what you refer to as a 1-way check valve) to keep oil in the filter. And the fram X2 filters don't hold a candle to the K&N filters, not even close...And 5w50 is entirely too heavy for our engines. They require a 5w30 and if you like your warranty(and fuel economy) it is a good idea to stick at least somewhat close to that.I suggest that anyone that is curious about oil should visit the forums at http://www.bobistheoilguy.com and read up!--Matt
blk182@n7
Post by blk182@n7 »
I changed my oil for the 3rd time myself and changed from a M1 - 103 to the K&N hp1002 this thing is notacabley larger and fits just perfect. I did notice a drip on the filter anfter a test drive bringing her into lift 3 times. but i tighted it and drove again and no drips. i might not have put enough oil on the seal, but i might just have go to the correct size k&N from now on. oh yea Mobil 1 5w-30. I will check again in an hour to see if there are any leaks....
2003 Mono Abyss GT,Moon and Tunes17 " Sport Max 929, Eibach Pro SpringsDunlop 215 50/RZ17 tires oem, Coustic 601SE amp, 2 CF1044 10" GM Top Rear Spoiler, Optima 51R Yellow TopAEM Short intake Blue, Progress Rear Anti Roll barFlowmaster Delta Flow 60 Series, Ground wiresDenzo IK 20 5304 plugs,TRD STB Front, Brass Bushings
DavidPIL
Re: (blk182@n7)
Post by DavidPIL »
Hiya...I didn't notice any leaks with mine. I did, however have a bit of a mess. Every time I remove the filter, after draining the oil, I get major spillage out from around the filter so I'm cleaning up a lot around the edge of the pan near the filter and even the seat for the filter. I always get oil dumped on me. Just make sure you're not over tightening. I will hand-tighten up to about 3/4 turnpast the point it seats. I wouldn't think any less would be sufficient and much more than a full torn would be too tight. The K&N filter has worked like a champ for me. The engine seems a bit quieter and it overall more smooth through acceleration. I dunno but it sure was worth the 3x price over a regular filter though there seems to be a $3-$4 price difference locally. Worth the money though.Dave
blk182@n7
Post by blk182@n7 »
do you use the hp1002
DavidPIL
Re: (blk182@n7)
Post by DavidPIL »
Heya...Sorry I didn't specify that. Yeah, I had talked about using the K&N 1002 in another post. It was late and thought this was the thread...Anywho, yeah, I use it, will probably use it exclusively. Also use Mobil 1 oil though bought 5 Quarts of Redline for my next oil change. That was nearly $8 a quart so I may not do that too often.Dave
blk182@n7
Post by blk182@n7 »
cool... well i drove her to work today about 15 miles in the 110 degree weather then drove at around 80 on the freeway home in 98 degree weather, then i checked the filter again and did not see any drips or leaks...
robodog61
Post by robodog61 »
Hello,I have the base engine and change my oil about every 3500-4000 miles. I use regular Mobil 5W-30 oil and Super Tech filters from Wal Mart. At $2 they are cheap, but are they OK? I figure that I change it enough that it isn't an issue. Any thoughts?
Wife_likes_her_vibe
Post by Wife_likes_her_vibe »
I saved money by not buying jack stands, just a jack. I put the jack under the Transmission or the oil pan.
ragingfish
Re: (Wife_likes_her_vibe)
Quote, originally posted by Wife_likes_her_vibe »I saved money by not buying jack stands, just a jack. I put the jack under the Transmission or the oil pan.You're kidding me, right???
2009 PONTIAC G8
tothebone
Re: (ragingfish)
Post by tothebone »
Anyone know if you can use a PF54 oil filter for the base vibe? Any info would be appreciated.
You can't just force a "Yeah, Dude."Satellite 2-tone with some other junk....
jake75
Post by jake75 »
My Pontiac dealer had this Oil Change Club Card that gives you 10 oil/filter changes for $119.99. Certainly can't change your own oil at that price. On my 2004 Chrysler T&C they sold me a "service contract" that was ten oil changes for $100. Alternatively, it seems that someone (Goodyear, Procare etc.) is always running a $14.95 oil/filter change coupon. At 6,000 miles on the T&C I used a Goodyear oil change coupon that included a tire rotation all for $19.99.I'm convinced that oil changes every 3000-4000 miles with good quality fossil oil will be as good as Mobil 1 especially for the way I drive.
simon
Post by simon »
Anyone looking to check which filter is right size in the book at the store might be surprised to find that Pontiac Vibe is not in the car section its in the truck section!
syclnjr
Post by syclnjr »
When I first changed the oil in my GT I used the best of everything as far as K&N filter and Mobil One syhthetic. changed the oil the second time and the oil was nasty and this was at just before 3000 mile interval. Also the valve train got a bit noisier on the Mobil one.Did alot of searching and decided to try Purolator Pure One filter and Castrol Syntec 0W30 Sythetic, the oil that it is imported from Germany and used specifically in Porchse's, Audi's etc.. I have had no porblems. Changed my intervals of changes to 6000 miles and the oil is half as dirty. Later
Mike2004 Vibe GT Abyss two tone, M/T, power package and 17's.
ScottS
Re: (syclnjr)
Post by ScottS »
I was thinking of trying CG on my GT for the next oil change. I am currently running the new mobil1 EP 15000. I figure I'll take it to 6-7k and pull a sample. Did you get a Used Oil Analysis on your GC?
04 GT Satellite MonotoneWith Stuff
Raven
Re: (simon)
Post by Raven »
Quote, originally posted by simon »Anyone looking to check which filter is right size in the book at the store might be surprised to find that Pontiac Vibe is not in the car section its in the truck section! Was that at Canadian Tire? When I forgot the Filter#, I always looked under Matrix when I couldn't find Vibe.
glassman
oil running down your arm!!!!!!
Post by glassman »
try taking a small center punch or philips screw driver and punch a hole in the filter before you take it off let it drain while you take the drain plug out then once it is done remove filter no mess to clean easy as 123
