pre-ignition beeping-make it stop, MAKE IT STOP!
Zig in East Orleans
Post by Zig in East Orleans »
When first putting the key in the ignition, there's a v. loud beeping that happens (about 4-5 beeps). A. is this necessaryb. how can i disconnect it?
Base '04 m/tone 5 spd Fusion Orange Wish:gimme a diesel version, I want to run B100!! Yokohama A008 (do they still make these?) Caught myself doing 140 km again, I think i have a speed problem.Time to go karting!http://www.topkarting.com/hull/action_g_p.php
ragingfish
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (Zig in East Orleans)
Post by ragingfish »
Is your door open when you put the key in?Is your seatbelt on?Closing the door and putting on your seatbelt before starting the car should yield no beeping at all.
2009 PONTIAC G8
NovaResource2
Post by NovaResource2 »
Quote, originally posted by Zig in East Orleans »When first putting the key in the ignition, there's a v. loud beeping that happens (about 4-5 beeps).Either your door is open and/or your seat belt isn't on.Quote »A. is this necessaryYes.Quote »b. how can i disconnect it?You can't. Close your door and put your seatbelt on before you put the key in the ignition and you won't have that problem.I'd also suggest reading your owners manual as this and more information is listed there. Hope that helped. Good luck and happy motoring!
Zig in East Orleans
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (NovaResource2)
ok, i feel stupidThanks guysI'm sure that'll work!
NovaResource2
Don't feel stupid, feel informed! I never put my seatbelt on first but I don't even hear the beeps anymore. I've learned to tune them out I guess.
scherry2
Post by scherry2 »
pull the audio warning buzzer
ragingfish
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (scherry2)
Quote, originally posted by scherry2 »pull the audio warning buzzer Has anyone successfully located it? Even with the dash off I couldn't find it...I was thinking of putting in a quieter one...not so piercing..
2009 PONTIAC G8
NovaResource2
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (ragingfish)
I don't think it can be removed. I believe it is a "black box" type item that does many things, not just the warning beeps .
ragingfish
Well, I pulled out the 'ol service manual. Appears it's part of the "multifunction alarm module." Even if your car doesn't have theft deterrent, it has that MAM block, and that's where it is.Oh well. No big.
2009 PONTIAC G8
scherry2
Post by scherry2 »
bummer nothing like the old days.
watts1371
Post by watts1371 »
If you want to "disarm" it, find the small black rubber knob on the driver's side door sill. It feels like a button and you'll notice that if you push it in, it tricks the car into thinking that the door is closed. If you like to run the radio while cleaning without running the engine, then find a way to keep that button pressed in. If worse comes to worse, take that button out and unplug the wires leading to it. The downside is that your "door" lights will not work when you open up the door. I did this with my old Honda. I guess it just depends what is more important to you.
pmh013
Post by pmh013 »
I think this is an American thing. As long as the door is closed, my car is quiet. I don't even think that it makes noise when my belt is off, just the flashing figure on the dash.Any Canadians confirm this? Or do I just have the stereo up too loud?
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
Jahntassa
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (watts1371)
Post by Jahntassa »
Quote, originally posted by watts1371 » If worse comes to worse, take that button out and unplug the wires leading to it. The downside is that your "door" lights will not work when you open up the door.Also, if you have the factory installed alarm system, or an aftermarket alarm system, i'd suggest not permanently disabling the door trigger, else someone would be able to open your driver door without triggering the alarm.
ragingfish
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (Jahntassa)
Also, if you bypass that trigger, and you DO manually turn on lights (even without realizing it), you'll never get a warning when you leave the car...
2009 PONTIAC G8
drunkenmaxx
Post by drunkenmaxx »
uh, my car beeps when i don't wear my belt???
watts1371
Post by watts1371 »
Yeah those are the downfalls, but if it really bugs you that bad to have it beeeping, disarming is the best way to get rid of it.
ragingfish
Re: pre-ignition beeping-make it stop, MAKE IT STOP! (drunkenvibe)
Quote, originally posted by drunkenvibe »uh, my car beeps when i don't wear my belt??? when you first start it, yeah.
2009 PONTIAC G8
pmh013
Post by pmh013 »
Quote, originally posted by drunkenvibe »uh, my car beeps when i don't wear my belt??? I listened very carefully the other day. It beeps about 5 times, then that's it. It's easy to miss! (I did)
