When first putting the key in the ignition, there's a v. loud beeping that happens (about 4-5 beeps). A. is this necessaryb. how can i disconnect it?
Base '04 m/tone 5 spd Fusion Orange Wish:gimme a diesel version, I want to run B100!! Yokohama A008 (do they still make these?) Caught myself doing 140 km again, I think i have a speed problem.Time to go karting!http://www.topkarting.com/hull/action_g_p.php
Is your door open when you put the key in?Is your seatbelt on?Closing the door and putting on your seatbelt before starting the car should yield no beeping at all.
Quote, originally posted by Zig in East Orleans »When first putting the key in the ignition, there's a v. loud beeping that happens (about 4-5 beeps).Either your door is open and/or your seat belt isn't on.Quote »A. is this necessaryYes.Quote »b. how can i disconnect it?You can't. Close your door and put your seatbelt on before you put the key in the ignition and you won't have that problem.I'd also suggest reading your owners manual as this and more information is listed there. Hope that helped. Good luck and happy motoring!
ok, i feel stupidThanks guysI'm sure that'll work!
Quote, originally posted by scherry2 »pull the audio warning buzzer Has anyone successfully located it? Even with the dash off I couldn't find it...I was thinking of putting in a quieter one...not so piercing..
Well, I pulled out the 'ol service manual. Appears it's part of the "multifunction alarm module." Even if your car doesn't have theft deterrent, it has that MAM block, and that's where it is.Oh well. No big.
If you want to "disarm" it, find the small black rubber knob on the driver's side door sill. It feels like a button and you'll notice that if you push it in, it tricks the car into thinking that the door is closed. If you like to run the radio while cleaning without running the engine, then find a way to keep that button pressed in. If worse comes to worse, take that button out and unplug the wires leading to it. The downside is that your "door" lights will not work when you open up the door. I did this with my old Honda. I guess it just depends what is more important to you.
I think this is an American thing. As long as the door is closed, my car is quiet. I don't even think that it makes noise when my belt is off, just the flashing figure on the dash.Any Canadians confirm this? Or do I just have the stereo up too loud?
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
Quote, originally posted by watts1371 » If worse comes to worse, take that button out and unplug the wires leading to it. The downside is that your "door" lights will not work when you open up the door.Also, if you have the factory installed alarm system, or an aftermarket alarm system, i'd suggest not permanently disabling the door trigger, else someone would be able to open your driver door without triggering the alarm.
Quote, originally posted by drunkenvibe »uh, my car beeps when i don't wear my belt??? I listened very carefully the other day. It beeps about 5 times, then that's it. It's easy to miss! (I did)
