Stobe lights? How to?
wicked1981
Post by wicked1981 »
So last year I purchased a strobe light kit at Autozone for at the time my Chrysler Sebring like the one that cops use on their emergency lights but not as strong. Comes with sleves to change the colors from blue, red, purple and white I tink. Never used it and was sitting in my garage till yesterday when I was putting some stuff in the garage and found it. So I installed them (mostly) last night but I have a question. I supposed to plug them to the battery but I have to buy a switch to turn them on and off from the inside of my car. My question is can I use the button located under the air conditioning buttons? There is 3 buttons A/C, Inside or outside air, and then a blank one. It has no use that I can see it cannot be pushed like regular buttons. So is it something I can use? How? What do I need to buy? From where? Or do I just need to go with one like the attachment? Im not an electrical person so im clueless in this section. Any help?
2006 Pontiac G6 GTP3.9L V-6 240hp and 241 lb-ft or torque18" Aluminum, five-spoke, flangeless200 Watt, 8 speaker Monsoon sysChrome dual exhaust tipsLiquid Silver MetallicBorla Custom ExhaustDr. Speed Cold Air Intake
Thenotorioussig
Re: Stobe lights? How to? (wicked1981)
Post by Thenotorioussig »
no that button has something to do with the ac unit and it has something plugged into it i think i read somewhere...what youll probably have to do is what im doing to run my neons, install a switch over to the left of the steering wheel by the hatch release and the coin holder thing... you can pull out the coin holder and then stick your finger around and pop out one of those spacer slots and then install a switch there...
----------------------------------------------------------------------2004 Base Vibe FusionMods:Grafxwerks StickersIn Car NeonsWindow Tint CAI (Possibly soon)Lowering Kit (Alternative to CAI)
AKLGT
Post by AKLGT »
the bottom button is blank, but you can't press it in w/o some kinda switch. i used that button to install the red led light for my back up indicator on my GT. i would probably use either one of the blanks on the left of the steering wheel or the good for nothing "coin holder" on the center console. if i intall the heated seat element on the passenger side, that's where i planned on placing the switch. other than that, you are best to ask jahntassa or joatman or cdfxer or anyone of those guys that understand the schematics in great detail.
AKLGT1998 Subaru 2.5RS
ragingfish
Post by ragingfish »
i agree with what hope said...install a switch in one of those extra spaces next to the hatch glass release button, or buy a blank plate and install it under the ebrake. that "button" under the a/c button is a decoy, just there to hide the mechanism that disengages cabin recirculation when the mode knob is turned to either defrost/floor or defrost...
2009 PONTIAC G8
Jahntassa
Post by Jahntassa »
The switch you have pictured is a bit overkill. I think that's an AC switch, not necessarily for cars. You can get a low-power DC switch at Circuit City (we carry APC stuff now..yay), or at a car shop. Even radioshack will carry it. I just use small toggle switches.If you go to an autoparts store, you can get a lighted on/off switch so you know when they're on. That's probably the best idea. I agree with Hope and Mike, put it to the left of the steering wheel in one of the blanks.
ebslopp
Post by ebslopp »
You could also get a light up toggle switch from Wal-Mart. There is another "blank" by the cup holders. That would be another possible location for your switch.
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
Re: (Jahntassa)
Quote, originally posted by Jahntassa »If you go to an autoparts store, you can get a lighted on/off switch so you know when they're on. That's probably the best idea. I agree with Hope and Mike, put it to the left of the steering wheel in one of the blanks.Yep, I agree as well... I would say use one of the blanks. Pep Boys sells an 'OEM-Style rocker switch' that will snap right into place, no cutting, no drilling. I used it for my light sensor disable project, mounted right next to the hatch glass release switch.
03VibeGT6Spd
Post by 03VibeGT6Spd »
what ever you do don't wire it direct, your taking a chance on shorting out something.Use a relay, I perfer to use bosch SPDT.I doubt you understand relays since your not talking about using one, So here is a link.http://www.underthedash.com/relayindex.htmlScroll down to Adding Accessories, the ground wire runs to your switch inside the car.If you get a short the worst thing is your accessories comes one.If you have any questions just ask.
wicked1981
Re: Stobe lights? How to? (03VibeGT6Spd)
Shoot you are right I didnt install one. Do I really need one? This is the kit I bought different brand though.Neon Car Strobe LightsDual Strobe light using 12V power for your vehicle! Flashes bright output great for custom installation stereo's, car shows, custom alarm systems and your home!Can change the color to RED BLUE PURPLE CLEARCan custom installed in headlights, subwoofersCan vary strobe speed with knob for lighting effects
03VibeGT6Spd
Well you didnt, but your taking a chance.I wouldn't take the chance for a $5 relay.if you mess up a something or even your CPU you'll be very sorry.Electrical or Electronic work is very expensive and if it's your fault warranty won't cover it.
