Bad Torque Steer
ALi3N
Bad Torque Steer
Post by ALi3N »
I know that front-wheel drive cars will naturally pull in one direction when under heavy acceleration but my GT torque steers whenever my foot is moving. If i am under any acceleration the car pulls right, if i am coasting (foot off the accelerator) the car pulls left. Anyone else get this? I am talking about a pull hard enough to change lanes.
ALi3N aka Dj ViP3RThere is a force through the euphoric beat causing uncontrolablemovement of your body, I am that force. Take a journey beyond the limits of your mind.'Download Mixes:http://shlrm.org/DjViP3R/http://www.myspace.com/djvip3r Latest Mixes: 'Nightlife' & 'M0Ti0N -X-'Pimpin' Abyss Vibe GT w/ Nav
AKLGT
Re: Bad Torque Steer (ALi3N)
Post by AKLGT »
mine pulls a little to the right when i'm pedal to the metal. but i'm used to it now... so doesn't bother me at all.
AKLGT1998 Subaru 2.5RS
ragingfish
Post by ragingfish »
I've noticed mine pulls strongly to the right anytime I have rapid DEceleration...If I'm going 70, and I hit the brakes to merge into an offramp in 500-1000 feet, I'll feel like I'm about to run off the road. It's scary sometimes.
2009 PONTIAC G8
goodvibe
Re: (ragingfish)
Post by goodvibe »
Mine's actually very good about staying put. There's a bit but less than I've had with other front drivers with less power. If I took my hands off the wheel I'm sure it would drift but it's never trying to pull the wheel out of my hands and I've had cars that did. Ragingfish. If your brakes are causing it, it's not torque steer. That doesn't seem right. Get em checked if it happens when out of gear or the clutch in. If your front end is off alignment buy being open on the toe adjustment, it could add to the Torque Steer problem.
philndz
Post by philndz »
check your tires....when my tires wore out (past the illegal tread depth) the torque steer became unbelievable. Might be time to rotate tires or replace them....just a suggestion.
2003 Shadow Vibe Base 5spd - 53,000 MilesFlowmaster 60 series exhaust - Short Ram Intake SystemKonig Kaliber 17x7 Rims w/ 225-45-17 Kumho Ecsta 711's - Hotchkis Springs - Progress Rear anti-sway Bar My Vibe is FOR SALE: $8900
ALi3N
Re: Bad Torque Steer (philndz)
Post by ALi3N »
Nope, not the tires. They are still good. Thankfully even under hard braking i can take my hand off the wheel (in theory of course) and the car stays put.As an example i have to adjust the steering wheel when i shift because the little jump coming into the next gear makes the car want to go right.
ragingfish
Re: (goodvibe)
Quote, originally posted by goodvibe »Ragingfish. If your brakes are causing it, it's not torque steer. That doesn't seem right. Get em checked if it happens when out of gear or the clutch in. If your front end is off alignment buy being open on the toe adjustment, it could add to the Torque Steer problem.I've had this car aligned 4 times in 2 years. Never been able to get rid of the problem. Came to accept it as normal.
2009 PONTIAC G8
Nervous_Dog
Re:
Post by Nervous_Dog »
I notice it more when I'm running my fatter summer tires then with the stock tires but yeah, it can be really bad under hard acceleration.
Nervous Dog2003 Monotone Lava GT w/ M&T and PowerMods: 18" Bronze Tenzo-R Mean Six rims w/ Kumho MX12" Rockford Fosgate Punch Sub in slot ported box2 - Rockford Fosgate Punch 201S amps2 pair - Rockford Fosgate P162C in front/rear doorsSony Xplod 5710 head unitHidden Hitch
goodvibe
Re: Re: (Nervous_Dog)
Post by goodvibe »
silverawd26, That makes sense but isn't torque steer. A toe out makes it want to follow grooves even more.
