Front Turn Signal Change?
ALi3N
Post by ALi3N »
Ok, i have decided to put white turn signals in the front and i can't figure out how to get the harness out to swap the bulb.Oh, and before it is brought up, yes they are legal in Texas. The white bulb shines through an amber lens for the side marker.
ALi3N aka Dj ViP3RThere is a force through the euphoric beat causing uncontrolablemovement of your body, I am that force. Take a journey beyond the limits of your mind.'Download Mixes:http://shlrm.org/DjViP3R/http://www.myspace.com/djvip3r Latest Mixes: 'Nightlife' & 'M0Ti0N -X-'Pimpin' Abyss Vibe GT w/ Nav
ebslopp
Re: Front Turn Signal Change? (ALi3N)
Post by ebslopp »
If it looks amber even if you have a white light, then why do you want to change it?EDIT: Oh, I see. The amber lens is on the side, but it has a clear opening on the front. There are instructions for changing the bulb in the owners manual, but they suck. I'll see if I can figure out how to change them tonight.
--------------------------------------------------------------------------------2004 Base - TwoTone Neptune - 5 speed There are 10 types of people in life. There are those who understand binary and those who do not.
ragingfish
Post by ragingfish »
You ARE aware the lens on this car is not colored, right? It would flash the color of the bulb...
2009 PONTIAC G8
Jahntassa
Post by Jahntassa »
I think it's a pretty painful job, I'll know more tomorrow when I attempt it myself.Today rather..as it's now past midnight...whoops..
ALi3N
Re: Front Turn Signal Change? (ragingfish)
Post by ALi3N »
Yeah ragingfish i know it would, that's the idea. I want a white indicator and turn signal in the front. Luckly for me the side indicator on the vibe shines through an amber lens so it would still be legal in Texas. I just can't figure out an easy way to disconnect the bulb housing from the back of the headlamp.It is nice to know people care enough to tell me these things though. Thanks guys.
ebslopp
Post by ebslopp »
OK, I changed my front turn signals to silver stars today. They were really easy to swap, but getting at them is a #$!@#$!@. Especially the driver's side!You have to kind of wrap your arm around a bracket and inbeween the battery (might be easier if you remove the battery, but I'm too lazy). but if you can grab the harness, you just turn it counter clockwise and it should come loose.
ALi3N
Re: Front Turn Signal Change? (ebslopp)
Post by ALi3N »
Oh! ok. I thought you had to push the tab on the top of the harness to unlock it. Thanx Ebslopp.
