Pontiac Vibe Intake Sensor Mod 20+hp
wicked1981
Post by wicked1981 »
Has anyone seen this? Tried it? Do you think it works? Any input? http://cgi.ebay.com/ebaymotors...25537
FusionVGT
Re: Pontiac Vibe Intake Sensor Mod 20+hp (wicked1981)
Post by FusionVGT »
This gadget can work, but the question is does it work on a Vibe. The idea is to fool a sensor (air intake temp, coolant temp) to feed the ECU a value that will make it advance timing. If it does work, I'd be suprised if it's anymore than 3-5 horse and even more suprised if the gains are permenant. The ECU makes a determination that the value it's getting is bogus and throws the CEL. You then reset the ECU and go at it again.Oh yeah, if you want to do this it may be no more than $2.00 worth of parts at Radio Shack
wicked1981
Re: Pontiac Vibe Intake Sensor Mod 20+hp (FusionVGT)
well I foind this one and this one..We guarantee that our Zero Gravity Module will outperform ANY other performance module on the market for under $175.00 http://cgi.ebay.com/ebaymotors...54425
AKLGT
Post by AKLGT »
i'd steer clear of those. get a real chip and do research on it. look at some dynos and make sure you're not throwing money away....
AKLGT1998 Subaru 2.5RS
