Loaded knuckle replacement for 2010 Vibe?
SeANMcBAY
Post by SeANMcBAY »
I have the 2010 1.8 FWD model and I'm wondering if this loaded knuckle will fit? Apparently the shop said mine is starting to roar?
https://www.amazon.com/dp/B083N16LSL?th=1
Thanks. I'd rather just replace the whole thing than worry about pressing bearings and such.
Kanovibe
Re: Loaded knuckle replacement for 2010 Vibe?
Post by Kanovibe »
Hi
I have replaced hub bearings and no big deal assembling them, at least the bearings can be of a known quality if from Toyota
John
In my experience, Toyota parts will fit the Vibe. But I question the quality of some non-OEM parts. I regret a couple of instances of going the cheapest way possible.
I've also had a front wheel bearing fail and I replaced the bearing alone. But I found out my local parts store did not have a press large enough for the work and had to go a little farther to a transmission shop. I paid a little more, about $40 I think, and had to wait most of a day. If I have to do the job again, I'll look at replacing the entire knuckle just to save the travel and down time.
Capt.Vibe
Post by Capt.Vibe »
I am having the same dilemma for my 2010 1.8L. How did that part fit? RockAuto does not list any knuckle bearing hub assemblies but has lots of options for the Corolla/Matrix. Should I just order from those? Should be direct fits?
2010 Red Hot Metallic 1SA
Engine, exhaust, drivetrain, brakes and suspension are all pure Toyota, according to all I've seen and experienced.
Capt.Vibe
Post by Capt.Vibe »
andrewclaus wrote: Tue Jul 14, 2026 3:51 am Engine, exhaust, drivetrain, brakes and suspension are all pure Toyota, according to all I've seen and experienced.
Yes exactly but RockAuto does not list any knuckle/hub assemblies for the Vibe and neither do the parts manufacturers list fitment for the Vibe which I find strange. Same with Amazon It's giving me pause for caution.
Example: None of these parts say they fit the Vibe.
https://www.rockauto.com/en/catalog/toy ... mbly,10923
