Hi.
06 pontiac vibe.
I had a p0171 lean bank 1 code and replaced the intake manifold gasket and throttle body gasket. So that gave me some more umph I was missing and helped steady the rpms while running. However, I recently noticed a new (small drops) oil leak on the driveway. Passenger side, looks like above oil pan, some is on lip of oil pan seam (very little definitely fresh oil appearance), but there's more above it and none dripping down to buttom of pan, just off oil pan lip. Above the pan to the front and driver side, near center line of the body, there's a thick spray of globs thay appear to be sprayed from below. There is some spray to the side of the area as well (towards passenger side of car). Just curious what is located in this area and any ideas what might cause that kind of leak? I've done many repairs on it, but I look up how to's. I don't know a lot about everything I'm looking at in this area. I will post pictures soon if needed.
