Hey this reply might be eight months late but your wheels look good. At one point I spray painted my oem steel wheels high gloss black too. It looks pretty good with tuner lugs.. my hubcaps have been long gone for awhile.
I also really like your backup camera vibenation I have thought about ordering one but the unit is was looking at doesnt install flush into the dash llike yours.
Well, today ive teared up my 09 vibes fuse box. My hvac controls have stopped working. After checking all the fuses, I decided to replace the fusesble link block assembly. According to my fuse schematic it contains a 50 amp fuse to the hvac system. The part cost $35 and replacing it is taking a shot in the dark. Spoiler alert: I missed.
- 20250601_151851.jpg (624.04 KiB) Viewed 1162 times
Note my trusty TRD strut brace!
- 20250601_151853~2.jpg (832.44 KiB) Viewed 1162 times
Had the jank out the air box and ecm. Wasn't too hard.
- 20250601_154852.jpg (583 KiB) Viewed 1162 times
The fuse box pops open like a clamshell.
I ended up sorta breaking the original fusible link block trying to pry it out of there. Eventually, I found a YouTube video showing the few clips I had missed that needed to be popped out to remove it. The fusible link block pops out attached to the plastic block populated with smaller fuses above it. Good old YouTube to the rescue. Thanks AUTOTUB3
https://youtu.be/mGmORcPmZ5k?si=ffK_dcbrdcSkcuLp
- 20250601_154007.jpg (484.27 KiB) Viewed 1162 times
Making note of where the wires go. I actually swapped the wires one at a time on the new fusible link block as to avoid mixing them up.
- 20250601_151847 (1).jpg (695.05 KiB) Viewed 1162 times
Its in there!
Whelp that didn't fix my hvac..
Its a bummer that ive sorta broken up my oem part which is probably better than the replacement. Though, they look pretty much identical besides the replacement (fusible link block) having one extra connection not used by my car.
Ive ordered a used replacement hvac switch. Its the control which resides in the center dash. Also had to order some new air filter assembly clips and a clamp for the air hose. I broke some other stuff during this process.
My car is showing its age. Theres a lot of rusted stuff.
Thats $50 for a used switch. I'll see how that goes. It would be nice to have a working AC this summer. My sunroof is getting a little more use lately without a working AC or blower fan at all for that matter.
