Vibe GT 2ZZ ECU Pinout?
SenatorChinchilla
Post by SenatorChinchilla »
Hello,
I joined the forum back in late February/early March after buying a gunmetal grey Vibe GT from an online auction. It ended up being terribly rusty underneath and I decided to use the 2ZZ-GE for a swap into an 8th gen Corolla. Now I'm doing the wiring and I've discovered my ecu pinout for the Vibe is wrong.
Does anybody have a pinout/diagram of the ECU? Or know where I can get one? I saw a helpful diagram naming each sensor as it sits on the engine, but I can't for the life of me find a diagram with the computer pins labelled.
Re: Vibe GT 2ZZ ECU Pinout?
The closest I have is the attached pdf of the engine control wiring diagram for a 2003 Matrix.
016ecs.pdf
(157.44 KiB) Downloaded 311 times
The matrix will be very simliar to the Vibe. However, there will be minor difference between 03, 04, and 05-06.
03 didn't have smog pump, 04+ did. 05-06 had totally different changes.
Depending on the year you have, there are a few people who can flash 05+ GT ECU's, and that may be an option for you.
SenatorChinchilla
Thanks guys. Fortunately it's a 2003 so I don't have to deal with all the smog related items.
