Bookworm wrote: ↑Sun Aug 25, 2019 6:29 pm Is it dripping from the drain .... Okay, the obscenity filter is set a bit too high. Let's try 'stopcock'. If so, you may have a piece of something stuck in the valve itself. Other than that - all I can suggest is look for whence the drip cometh. If you were messy at filling the top, it could simply be coolant working its way down the outside.
x2.Bookworm wrote: ↑Sun Aug 25, 2019 6:29 pm Is it dripping from the drain (removed)? If so, you may have a piece of something stuck in the valve itself. Other than that - all I can suggest is look for whence the drip cometh. If you were messy at filling the top, it could simply be coolant working its way down the outside.
