radiator wont shut 07 vibe
murdermitten99
Post by murdermitten99 »
doing a radiator drain and closed the bottom plug up but its still heavily dripping. anyone ever have that problem? gonna drain and check in the am when its cool
Bookworm
Re: radiator wont shut 07 vibe
Post by Bookworm »
Is it dripping from the drain (removed)? If so, you may have a piece of something stuck in the valve itself. Other than that - all I can suggest is look for whence the drip cometh. If you were messy at filling the top, it could simply be coolant working its way down the outside.
Bookworm
Post by Bookworm »
Bookworm wrote: ↑Sun Aug 25, 2019 6:29 pm Is it dripping from the drain .... Okay, the obscenity filter is set a bit too high. Let's try 'stopcock'. If so, you may have a piece of something stuck in the valve itself. Other than that - all I can suggest is look for whence the drip cometh. If you were messy at filling the top, it could simply be coolant working its way down the outside.
Bookworm wrote: ↑Sun Aug 25, 2019 6:29 pm Is it dripping from the drain (removed)? If so, you may have a piece of something stuck in the valve itself. Other than that - all I can suggest is look for whence the drip cometh. If you were messy at filling the top, it could simply be coolant working its way down the outside.
x2.
murdermitten99
fixed it. just cleaned up the plug and reinstalled.
got another issue or two ill create another thread soon. thanks everyone.
Bookworm
Post by Bookworm »
You're welcome. Glad that one was easy to clear up.
