Thanks I will give it a try.
Funny thing about that "black area marks non-visible from inside car" thing. I can still see some of the wiper from in the car,
Edit: I just did my best to adjust them.
The drivers side was very easy, I put it up a bit, no probs. It moved easily. The passenger side was another story and left me disappointed. It would not adjust easily, I had to pull it all the way off the pivot mount and it would only go back down at specific intervals, making adjustment a pain.
I manage to either make it too high so the tip of the blade is easily visible on the windshield (but still below the black) which is kind of annoying. Or I can drop it lower, but it still somewhat hits the plastic piece although not as much. When I first adjusted it, I almost couldn't get it back off the pivot mount again and almost freaked out.
Also did gain some room it looks like to install a 22" blade if I wanted on driver side, there is a bit of a gap between the driver and passenger blade near the bottom of the windshield, which won't get cleaned as it is currently set. Maybe a larger blade will fix that.
Here are my new wiper positions, and the annoying view from the inside. idk I guess I like a "clear" windshield area.
- wipers1
- clipimage.jpg (41.19 KiB) Viewed 11124 times
- wipers2
- clipimage.jpg (60.23 KiB) Viewed 11124 times
- wipers-inside
- clipimage.jpg (50.69 KiB) Viewed 11124 times
