2003 GT passenger side cv shaft carrier bearing pressed in or not?
Vortec
Post by Vortec »
GF's 03 GT has a worn inner cv joint on the passenger side (boot cracked, lube got out, moisture got in...you know the drill).
i've seen conflicting information regarding whether the carrier bearing is actually pressed onto the shaft and into the support and the manuals are vague. to me, it appears that the bearing is pressed onto the shaft and then held into support via the two bolts and snaprings...and probably rust.
this would be very helpful info to have before i start ripping the car apart.
Thanks
2009 Vibe GT, 2003 Vibe GT
ImUrOBGYN
Re: 2003 GT passenger side cv shaft carrier bearing pressed in or not?
Post by ImUrOBGYN »
If it's rust, I have some I'll ship you. Brought it to Texas from Ohio with me. Top quality, midwest, salt-belt rust. Let me know.
:D
