Do 09 Matrix heated mirrors fit 09 Vibe?
peacock
Post by peacock »
I have been thinking of installing heated mirrors in the Vibe. Apparently this was an option on the Matrix. Does anyone know if the mirrors are interchangeable on our vehicles? I'd rather replace the whole mirror assembly than take it apart and glue on an element.
Amazon does not think it would fit but I suspect that it might.
http://www.amazon.com/Toyota-Matrix-Hea ... icleType=5" onclick="window.open(this.href);return false;
wiresbringit
Re: Do 09 Matrix heated mirrors fit 09 Vibe?
Post by wiresbringit »
Did you risk it and find out?
2009 Blue AWD 2.4L
NascarXprt
Post by NascarXprt »
Yes, the whole door assembly of the 2nd Gen (09-10 Vibes and 09-13 Matrix) are interchangeable within the two cars.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
richz03
Post by richz03 »
My passenger mirror was broken when I bought the car so I just ordered a used Matrix heated mirror to replace it. I hope to get it on this weekend. I'll keep you guys posted.
Rich
richz03
Post by richz03 »
Still haven't installed the heated mirror. So does the car give power to the Vibe mirror harness when the defrost is selected?
Rich
ctgottapee
Post by ctgottapee »
Getting power to it and making it look nice will be key as its doubtful that wiring exists
richz03
Post by richz03 »
From my understanding the wiring is identical so this is a true bolt on...... they are activated when you select defrost mode on dash and automatically turn off in 15 minutes.
Rich
^ If that's the case, I will definitely be doing this mod!
enfield577
Post by enfield577 »
NascarXprt wrote:Yes, the whole door assembly of the 2nd Gen (09-10 Vibes and 09-13 Matrix) are interchangeable within the two cars.
Does that mean that I can use Matrix parts to replace my door liners (front and rear) where the paint flaked off on the upper surfaces?
vibenvy wrote:^ If that's the case, I will definitely be doing this mod!
Did you do this, Carrie? I would LOVE to put these on my car ... heated rearview mirrors is something I really miss from my VW.
I would assume so Geoff.
No. I haven't even looked into it all. I wasn't even aware this was an option on the Matrix :|. I will definitely post any info I can track down on this topic though ;)!
amedeovibe
Post by amedeovibe »
Hi guys. Any updates to this thread? Has anyone installed matrix mirrors to the Vibe and do they end up heating or not?
THanks!
amedeovibe wrote:Hi guys. Any updates to this thread? Has anyone installed matrix mirrors to the Vibe and do they end up heating or not?
THanks!
I don't think any of them have done this. I would presume in theory, everything is there to have them work properly since the vehicles are basically identical.
exige1992
Post by exige1992 »
is there an update on this thread? i would love to know if this can be done
2009 Vibe 2.4L 5speed fully optioned base model
I'll have to check the "Helms" manuals to see if the wiring harness/connectors to the mirrors INCLUDES a defrost circuit. I'm guessing NOT!
2014 Silverado, 2004 Vibe GT
Now that I think about it, the Vibe would NOT be prewired for heated mirrors. The Matrices were built in Canadia while the Vibe at NUMMI in California. The mirrors should fit, but you'd have to run your own wiring.
cq358
Post by cq358 »
I should had posted my thread in here
viewtopic.php?f=28&t=47032
