I was looking at some 16" x 6.5" wheels for winter tires. Is there any other consideration for them fitting on the Vibe? I didn't see an offset listed. The wheels were on TireRack.com. Thanks!
The stock offset for the 16x6.5" wheels are +39mm. The stock offset on the 17x7" wheels is +45mm. The brakes on these cars are relatively small compared to the diameter of 16" wheels, so there should be no fitment issues.
The only other thing to consider is center hub size is 54.1mm and our cars are hub centric. If you purchase wheels with a hub larger than this you will need a hub ring to match them up. Unless the wheels have conical lug holes, in which case you will need conical lug nuts to go with the rims.
