Wheels for winter tires
NibCrom
Post by NibCrom »
I was looking at some 16" x 6.5" wheels for winter tires. Is there any other consideration for them fitting on the Vibe? I didn't see an offset listed. The wheels were on TireRack.com. Thanks!
SeattleJeremy
Re: Wheels for winter tires
Post by SeattleJeremy »
The stock offset for the 16x6.5" wheels are +39mm. The stock offset on the 17x7" wheels is +45mm. The brakes on these cars are relatively small compared to the diameter of 16" wheels, so there should be no fitment issues.
The only other thing to consider is center hub size is 54.1mm and our cars are hub centric. If you purchase wheels with a hub larger than this you will need a hub ring to match them up. Unless the wheels have conical lug holes, in which case you will need conical lug nuts to go with the rims.
thebarber
Post by thebarber »
15x6 like a corolla... 195-65-15
Cheaper setup
Since we don't know for which Vibe: make sure you have the correct bolt pattern.
Here is a helpful website:http://www.roadkillcustoms.com/hot-rods ... z3jBWU14iv
NibCrom
Post by NibCrom »
Thanks for the replies.
Anyone know a good place to purchase 15" wheels?
NibCrom
Post by NibCrom »
Found some on TireRack. You just have to select the winter wheel/tire package.
@ NibCrom: What year is your Vibe?
NibCrom
Post by NibCrom »
2005.
NibCrom wrote:2005.
Okay. If it was a 2nd gen, I was just going to remind you of the two different bolt patterns, but no need since it's a 1st gen.
NibCrom
Post by NibCrom »
vibenvy wrote:
NibCrom wrote:2005.
Thanks for asking. :)
