I got codes: 35, 37, 52, 53, 54cythraul wrote:Excellent, thank you!
I got codes 43 and 53. Any idea how bad it is?
cyth
EDIT: Apprently I had the passenger air bag recall due. I was lucky to get an appointment today. Taking the time to browse while waiting and it looks like the SDM module will have to be changed.
Toyota part is 89170-01060 and GM's 88973569. Toyota dealer wants a bit under 400$, GM almost 500$ and ebay got one used for 50$.
I'm in Canada so online parts are rare and duty fees enormous.
EDIT2: Looks like I'm "lucky" as it's only the steering coil.. 152$CAN plus 1h of work. I'd do it myself but I need to leave on holidays and can't spare the time.
Hi Gary,GaryG92 wrote:Did changing yours take care of the airbag light?
Thanks for the comment. I got really bored yesterday and took apart a lot of my interior. I found the the sdm module goes, and found a brand new one online made by GM for 1/4 of the price the dealership was charging me. My only questions now are: does it need any type of Vin specific coding done, and is this really the problem I'm having? I'm not sure I fully trust in the dealershipcythraul wrote:Hi Gary,GaryG92 wrote:Did changing yours take care of the airbag light?
I did not change the SDM module. I changed the steering coil which was less expensive. If you're in the US, there's plenty of sources to get an SDM module cheap and it looks very easy to swap yourself. Make sure you get one for your air bag system: if you have side air bags, the module is not the same.
cyth
not according to my research. I've red that SDM modules are drop in replacements but you have to make sure they are for the correct airbag system: with or without side air bags.GaryG92 wrote:does it need any type of Vin specific coding done, and is this really the problem I'm having? I'm not sure I fully trust in the dealership
I'm making sure to get the right part. Got the part number straight from my dealershipcythraul wrote:not according to my research. I've red that SDM modules are drop in replacements but you have to make sure they are for the correct airbag system: with or without side air bags.GaryG92 wrote:does it need any type of Vin specific coding done, and is this really the problem I'm having? I'm not sure I fully trust in the dealership
as for if it would fix your problem, I don't know enough about the codes having just recently learned of them.
