I have been getting I believe when I checked it the p0171 system too lean. Too much oxygen in exauhst. I know it's the sri. I can reinstal the stock intake without issue and it works fine.ImUrOBGYN wrote:Nope. Some people actually don't like oiled filters as they believe they can muck up your MAF. However, I'm not sure what kind of filter you have. It may be a dry filter.
First off, are you getting any codes?
If not, and you're absolutely sure you've connected everything properly, I would try reinstalling my stock intake and see what happens.
Not quite sure what the issue might have been. I took the last pipe that connected to the filter and turned it so it was facing downwards beside the battery. Car started up just fine without issue. Took it for a ride and seemed to have no problems at all. Maybe I tightened a screw down a tiny bit more or maybe the way I reassemeled the parts. Not completely sure. There must still be the smallest leak or something because I just threw a code. Car is running fine but gonna keep tinkering with it more.ImUrOBGYN wrote:So, spill the beans! What was the issue or what did you think was the issue?
Thanks! I actually have a CAI in the mail right now so that will be installed soon. It was an interesting little project though.ImUrOBGYN wrote:Well, better than not working, for sure. lol Good luck!
Positive. I ended up finding a CAI for a matrix on ebay and it works on my vibe perfectly.bluneon wrote:are you sure your p0171 code isn't due to a failing intake manifold gasket that is very common on the 1zz engines?
