Where to mount microphone?
drsus
Post by drsus »
Hi all, I just purchased a JVC radio with Bluetooth, and im having trouble deciding where to put the mic at. It would be awesome if i saw some pictures of your mic setup to give me some ideas. Thanks!
Fever
Re: Where to mount microphone?
Post by Fever »
Sorry don't have a pic, maybe tomorrow, but the Vibe I just got came with the mic dbl back taped to the flat of the steering column b/w the wheel and the instrument cluster. I don't see any wire so it must be hidden well (didn't really look that close yet) and seems to out of the way enough that I hardly notice it. Seems like a good spot.
'07Vibe '13FR-S '99Ranger
Fever wrote:Sorry don't have a pic, maybe tomorrow, but the Vibe I just got came with the mic dbl back taped to the flat of the steering column b/w the wheel and the instrument cluster. I don't see any wire so it must be hidden well (didn't really look that close yet) and seems to out of the way enough that I hardly notice it. Seems like a good spot.
I installed the mic on my son's car in the same place. Seems to work OK.
kumquat
Post by kumquat »
I had mine mounted on one of the ledges near the gauges and it worked OK.
Then I moved it so it's up at the top of the A pillar where the plastic meets the fabric. It seems to work better, probably since there's fewer surfaces reflecting sound around it,
SlammedNiss
Post by SlammedNiss »
kumquat wrote:Then I moved it so it's up at the top of the A pillar where the plastic meets the fabric. It seems to work better, probably since there's fewer surfaces reflecting sound around it,
Thats exactly where I have mine mounted.
2011 Rav4 Sport
drsus
Post by drsus »
Alright!! great ideas..but unfortunately i installed the mic and i found out its crap..no one can hear what im saying, i have to talk about 4 inches from the mic in order for it to work
kumquat
Post by kumquat »
Be sure the mic volume is turned all the way up.
drsus
Post by drsus »
Thanks kumquat, i completely forgot about that.. It works ok now : )
cptnsolo77
Post by cptnsolo77 »
This is what I did. I cut the base of the mic so that it would sit flat & attatched it with double-sided tape. No probs with sound quality. Very simple cable routing as well and absolutly no visible cables. No pulling trim panels or anything like that. It is well hidden & wont get hit by anything.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
drsus
Post by drsus »
WOW! that is a great spot. I'm going to use your idea. Thanks!!
ImUrOBGYN
Post by ImUrOBGYN »
kumquat wrote:I had mine mounted on one of the ledges near the gauges and it worked OK.
Mine is wired up thru the A pillar, as well. I have mine pop out there at the top by the sunshade swivel. Haven't had any issues. I do like the way cptnsolo77 has done it but I would be tempted to drill out a hole and actually insert the mic into it, leaving out just enuf to still pick up audio properly. Hmm, I may look around the car later to see if there's a spot begging for it. Thanks for the inspiration, cptnsolo77.
