Vibration or rattle at 2700 RPM
Ondersma80
Post by Ondersma80 »
Hello.
I have a 2006 Vibe with about 180,000 miles. I love the car... Aside from the rattles. Setting aside all the interior rattles, I have one metallic sounding rattle that occurs briefly at about 2700 RPM. It is a slightly higher pitch than the engine itself. It comes from the front end - I feel like it is lower front end. It has made that noise as long as I can remember - probably not as loud when I first got the thing. I asked at the dealer early on and they investigated and gave me the old "they all do that". I actually test drove another on the lot and it did make the same noise. I even went to another dealer to check a 3rd and it made the noise too. So, I just let it go.
If I accelerate hard it can only be heard very briefly at that specific RPM. If I accelerate slowly the noise lasts longer as I pass that specific 2700 rpm. If I set the cruise at about 2700 on the highway at around 75 mph it is a constant noise. It is like the engine vibration at that RPM makes something vibrate against something.
Any ideas on this?
Re: Vibration or rattle at 2700 RPM
Double check to make sure none of the heat shields on the exhaust system have come loose. It might just be a loose bolt on one under the car.
Ondersma80
Thank you very much for the suggestion. I'll dig out the jack stands and take a peak this weekend.
Derf
Post by Derf »
Some other things to check while in the air;
Link: viewtopic.php?f=12&t=42950&p=493114&hil ... se#p493114" onclick="window.open(this.href);return false;
campb292
Post by campb292 »
Sorry for bumping an old thread but I may have some help. I have a 06 with about 190k and had this rattle/vibration noise for about the last 50k miles. I crawled under myself to check shields, everything seemed fine. I took it to a shop, the tried for an hour to find the cause, nothing. Tried a GM dealer, no fix. Finally tried one more GM dealer and they took out a few bolts from the heatshield right behind the catalytic converter and replaced them one at a time. The culprit seemed tight on visual and touch inspection but must have allowed the vibration. My Vibe is like new for 6 bucks and an oil change, they didn't even charge labor. Try and go beyond just inspecting and get them to swap out bolts.
