manifold help
foamy302
manifold help
Post by foamy302 »
I have a 03 vibe gt that threw a bearing, replaced the engine and now the exhaust ports don't line up to the manifold, i believe the engine came from an 04 matrix XRS. Any help would be awesome
2000 Dodge Neon mtx 300k+ booger bushings,motor mount inserts. DD
2003 Pontiac Vibe GT 136k, stock for now. Wifes DD for now
klutzycarlover
Re: manifold help
Post by klutzycarlover »
If it is indeed a 2zz, the only issue I could think of is the injection ports. 2003 was the last year for the 2zz without air injection. This is a very simple solution, buy this kit from MWR, and just tap the holes in the head, and install the plugs. http://www.monkeywrenchracing.com/produ ... ts_id=2067
Also, what did you do with the last engine? If you still have it, I would love to buy it off you. I need a spare block to mock up mounting an awd transmission from a celica gt4.
foamy302
Re: manifold help
Post by foamy302 »
The old engine is gone, i had a shifty person replace the motor and he did a half a** job, long story. Bought the plug kit, any advice on it? ?
klutzycarlover
Re: manifold help
So you're positive that is the problem? If so...
Remove the heat shield if it is in the way. It's really tight back there, so it will be difficult.
Get a tap handle at a hardware store if you don't already have one. Put a bit of grease on the tap, and tap the holes. The grease will prevent most of the shavings from getting in the exhaust. Then just run the plugs in, and you're good to go.
foamy302
Re: manifold help
Post by foamy302 »
I have to take the manifold off first of course
klutzycarlover
Re: manifold help
No, you shouldn't have to.
foamy302
Re: manifold help
Post by foamy302 »
Looking back there the holes are half covered by the manifold. No problem
klutzycarlover
Re: manifold help
Half covered? The small 3/8ths air injection holes, right? Not the actual exhaust ports?
The air injection holes should be completely uncovered when you remove the heat shield.
foamy302
Re: manifold help
Post by foamy302 »
I have pictures but they are too big
foamy302
Re: manifold help
Post by foamy302 »
Here we go.
klutzycarlover
Re: manifold help
Okay. Ya, so just take off the manifold then. Should be pretty simple.
