The Vibe radios from 03-08 are the same, as long as they are the same type, with the amp or without. The reason the Matrix mounts are different like hoooboy said, is they used a GM radio in 03-04 and a Toyota radio from 2005 on. As for what other factory radios that will fit, that is a good question.
If you did want to go aftermarket, so as long as you get a faceplate adapter kit for a 2003-2008 Vibe, you are good. They have them for single and double DIN radios. The wiring adapter is a Metra 70 2003C harness to hook up an aftermarket radio. Here is a pic of the receiver I put in my son's 06.
