2 questions radio & PCV valve
Murdoc
Post by Murdoc »
first i have a base model 2003 pontiac vibe, i'm replacing the radio with another factory......its pretty much plug and play correct? Second question is i tried to replace the pcv valve and autozone have me the incorrect one, anyone have apart number? There is othetr threads on this but it doesnt have a specific part number.
Reaccion
Re: 2 questions radio & PCV valve
Post by Reaccion »
About the radio question, your radio should be plug and play always that the radio is from a Vibe or Matrix. If you buy another same looking like GM radio, it may require a security code or the radio may not work on your Vibe.
hoooboy
Post by hoooboy »
Radio brackets are differents so dont throw your OEM brackets in the garbage.
My friend have a XRS 2003 and I have a XRS 2005 and the brackets are not the same!
Reaccion
Post by Reaccion »
I was also looking on AutoZone, and I got the following part numbers for the PCV valve: Part Number: PC434, and Part Number: PCV1112DL. I hope that helps!
Reaccion wrote:I was also looking on AutoZone, and I got the following part numbers for the PCV valve: Part Number: PC434, and Part Number: PCV1112DL. I hope that helps!
Sometimes they put the wrong part in the box that has the right part number...I had that happen when I replaced mine. It takes less than 5 minutes to do the switch, so I recommend pulling the original off and bringing it inside the store to double-check.
Salsa Guy
Post by Salsa Guy »
On the 1zz they have 2 different thread sizes for some strange reason. I got the wrong one and had to return it. X2 pull the old out and double check
Murdoc
Post by Murdoc »
Is there any differences in the radio? Like in the face plate?
The Vibe radios from 03-08 are the same, as long as they are the same type, with the amp or without. The reason the Matrix mounts are different like hoooboy said, is they used a GM radio in 03-04 and a Toyota radio from 2005 on. As for what other factory radios that will fit, that is a good question.
If you did want to go aftermarket, so as long as you get a faceplate adapter kit for a 2003-2008 Vibe, you are good. They have them for single and double DIN radios. The wiring adapter is a Metra 70 2003C harness to hook up an aftermarket radio. Here is a pic of the receiver I put in my son's 06.
Murdoc
Post by Murdoc »
I ordered a radio it looks exactly like mine just worried about the programming deal.
Reaccion
Post by Reaccion »
viewtopic.php?f=18&t=39696&p=472962#p472962" onclick="window.open(this.href);return false;
Murdoc
Post by Murdoc »
Actually installed the radio 2 days ago, it came from a 2005 pontiac vibe, plug and play works perfect! thanks for the help AGAIN!!
Reaccion
Post by Reaccion »
Great! That would take care of that!!! :D
