What's needed if you add a SC to the base Vibe?
KSNeptune
Post by KSNeptune »
I feel like my Base Vibe/auto has good suspension and brakes right from the factory. But adding the SC will put it more into the GT's performance territory. Can anyone tell me what suspension and brake differences there are between a stock GT and a stock Base Vibe?Looking at the big tail pipe, and since Pontiac has been teasing about the SC since day one of the Vibe, I suspect some of the performance engineeringing upgrades are already in place in anticipation of the supercharger. I"d just like to know for sure.Anyone? KSNeptune
ragingfish
Re: What's needed if you add a SC to the base Vibe? (KSNeptune)
Post by ragingfish »
I know the GT has 4 wheel disc brakes...I'm not aware of any differences in suspension - I believe they are identical.
2009 PONTIAC G8
Vibe Rater
Re: What's needed if you add a SC to the base Vibe? (ragingfish)
Post by Vibe Rater »
You'll need money, lots of it.
satur9
Re: What's needed if you add a SC to the base Vibe? (Vibe Rater)
Post by satur9 »
suspension is the same.the disc brake thing has been beaten to death. you shouldnt need anything. i believe faultline still has stock brakes and his turbo has more power. if you WANT new brakes check out ssbc brakes these are the ones i want and are whats stopping 300hp+ matrixes.
ragingfish
Re: What's needed if you add a SC to the base Vibe? (satur9)
quote:suspension is the same.the disc brake thing has been beaten to death. you shouldnt need anything. i believe faultline still has stock brakes and his turbo has more power. if you WANT new brakes check out ssbc brakes these are the ones i want and are whats stopping 300hp+ matrixes.Just to clarify, I wasn't implying that when you get the S/C you need new brakes. Was just saying outside the engine and the tranny, the brakes were the only difference AFAIK between a GT and a base model...
2009 PONTIAC G8
NovaResource
Post by NovaResource »
Only the rear brakes are different, the front brakes are the same.
ragingfish
Re: What's needed if you add a SC to the base Vibe? (NovaResource)
Right.
2009 PONTIAC G8
Faultline
Post by Faultline »
quote:suspension is the same.the disc brake thing has been beaten to death. you shouldnt need anything. i believe faultline still has stock brakes and his turbo has more power. if you WANT new brakes check out ssbc brakes these are the ones i want and are whats stopping 300hp+ matrixes.yep it's true...I have not done any brake upgrades, and 9k miles later, since the advent of turbo, I cannot really tell that I need an upgrade, but I suppose I could tell the diverence..if I had one...I did lower my car w Eibach lowering springs.-sportline- aprox 2" drop, it did help w body roll, but not really nec...
pics 10/2/05 http://photobucket.com/albums/a386/Faultline05/2003 Base Vibe, frosty color,moon n' tunes packagemods: Eibach sportline lowering springs,17"centerline forged wheels -silver excels -Goodyear Eagle F1 tires 225/50/17's-ACT HD clutch,2.5" exhaust,ES motormount inserts,up graded to 6 spd transmissionStafford Fabrication turbo kit: Garrett T3 turbo, FMIC ,SF BOV. ,Alcohol/water injection,and SF centerfeed fuel rail
goodvibe
Re: What's needed if you add a SC to the base Vibe? (Faultline)
Post by goodvibe »
You wont need a thing. Your car handles plenty good for the extra power. The GT does have firmer shock damping but thats it for differences. For upgrades; The progress rear sway bar for about $100 is on of the most cost effective and funtional upgrades available.
meathead333
Post by meathead333 »
so whats the difference between the turbo and surper charger?
My myspace.com profile My 73' Bronco Cardomain page
satur9
Re: What's needed if you add a SC to the base Vibe? (meathead333)
Post by satur9 »
theres a rundown in the forced induction forum check there.
meathead333
yeah, i suppose there is a bunch there. sorry, brain fart.
